HP Elitebook 850 G4 bios dump
  • amiralipay
    • Oct 2022
    • 17
    • iran
    Re: HP Elitebook 850 G4 bios dump
    Hello, please fix my file
    The power and capslock lights are flashing
    • hoaca388
      Badcaps
      • Jan 2022
      • 12330
      HP EliteBook 850 G4 Notebook PC
      • amiralipay
        • Oct 2022
        • 17
        • iran
        Thank you, but he did not answer.
        It has the same problem as before
        • justice171
          • Feb 2018
          • 110
          • South Africa
          HP EliteBook 850 G4 No Post
          Good day,
          I have an HP EliteBook 850 G4 that runs FAN very Fast with No POST or Display. Please Help!
          Below are the attached BIOS and EC files.
          • DaMike
            • Oct 2023
            Elitebook 850 G4
            Hoping someone can help me out here. Replaced the motherboard with a used board. Now some of the hardware isn't working like touch screen, NFC. Minor inconveniences but I'd like to fix it if I can. I'm pretty sure it's because the feature byte on the new board doesn't have them enabled.
            Been researching getting the board to manufacturing mode. Tried to get the SMC.bin from HP, no luck. I read about changing the UUID to all FFs and I used the HP backup software to backup BIOS. Poked around with a hex editor and found 2 locations where the value exists in the backup. I really don't have the confidence to modify the file and potentially brick the board.
            Any way to get the board back into manufacturing mode?
            Motherboard: 6050A2854301-MB-A01 Product ID: X4B27AV SN: 5CG7494SDB
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              #26
              Re: Elitebook 850 G4
              Read the rules before posting:
              You MUST:
              • Use search function in case someone already answered your request
              • Post under a related thread if it exists
              • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
              • Provide a BIOS/EC dump if possible
              Thread merged.
              Become a Badcaps supporter
              Thanks to all supporters.
              • poweron
                • May 2019
                • 371
                • italy
                #27
                Hi everyone, I attach backup
                • rex98
                  • Feb 2023
                  • 1293
                  • Mandaue CEBU, Philippines
                  #28
                  describe your problem! and include serial number.
                  • poweron
                    • May 2019
                    • 371
                    • italy
                    #29
                    the problem is this: it turns on but the screen is black and the fan starts to spin at maximum after 10 seconds
                    the serial number is SN# 5CG7151JJX
                      Vesko356 commented
                      Editing a comment
                      Thread merged.
                      Please use the forum search to find related threads where you can post your request. You're NOT allowed to start a new thread if there's an existing one!!!
                      This is a second warning ,next time you will receive an infraction.
                  • godit3
                    chrisTech
                    • Nov 2015
                    • 29
                    • ghana
                    #30
                    it is fixed, got the main BIOS dump from other thread.
                    please where did you get your files from
                    • Ahari
                      by Ahari
                      I...
                      08-13-2025, 06:12 AM
                    • mkdj
                      by mkdj
                      Dear all,
                      10-19-2025, 04:41 AM
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • haitham sharabati
                      by haitham sharabati
                      Hello engineers 😀,
                      🔧 Device Info:
                      - Model: HP 15-da2007ne
                      - Product Number: 8XF55EA#ABV
                      - Serial Number: CND0338P0D
                      - CPU: Intel Celeron N4000
                      💀 Problem:😅
                      08-07-2025, 04:54 AM
                    • Citymin
                      by Citymin
                      S/N : 5RNK9FFT70...
                      08-05-2025, 05:12 AM
