Lenovo G700 BIOS request
  • Rhadu23
    • Mar 2021
    • 74
    • United Kingdom
    Can I please have a working BIOS for:
    Lenovo G700
    Model name: 20251
    S/N: AB20567927
    P/N: 59395272
    MO: AB04010501
    Saves attached
  • Rhadu23
    • Mar 2021
    • 74
    • United Kingdom
    Re: Lenovo G700 BIOS request
    The BIOS save that I have attached, makes the laptop to power on, fan working normal, but no display output.
    I have tried some from different threads, but those ones make the laptop completley dead.
    • peste
      • Dec 2016
      • 12729
      • ROMANIA
      bios extracted from the Lenovo site update
      DMI 20800-2092F
      KEYWIN 2CD000-2CD03F
      • Rhadu23
        • Mar 2021
        • 74
        • United Kingdom
        Thank you for the reply.
        After reprogramming, the laptop does not power on at all.
        It appears to be a BIOS issue, as with the old one, it powers on, fan spins normal, but no display.
          • 20781
          try these .
          G700 Laptop (Lenovo) - Type 20251
          • xpuko
            • Aug 2016
            • 56
            • Poland
            Hello, I have a Lenovo G700 BAMBI REV: 2.1
            S / N AB20389664
            P / N 59395525
            11S11201512ZZ0MLDB9A2D
            No picture turns on, two bios
            W25Q16, W25Q32
            I'm looking for the right bios.
            After programming the bios from the third post, the laptop does not turn on.
            After programming the bios from the fifth post, the laptop turned on after connecting the power supply (autostart), the image showed up.
            When turned on again, it turns on but no backlight.
            I'm looking for a suitable bios, thank you.
            in the attachment the original bios recorded with the programmer
            • hardware1
              • Sep 2021
              • 2930
              • N/A
              S / N AB20389664
              P / N 59395525
              W25Q16, W25Q32
              try and let me know if it works.
              all donations are welcome,
              • xpuko
                • Aug 2016
                • 56
                • Poland
                After programming the bios, the laptop turned on without backlight,
                It turned out that the Hall sensor at the switch is damaged. After
                replacing the sensor, the laptop works properly
                Thank you for your help
                • markus24
                  • Jul 2024
                  • 6
                  Hello, I have Lenovo G700 laptop as well
                  Lenovo G700
                  Model name: 20251
                  Mainboard: BAMBI REV: 2.1
                  S/N: AB20185212
                  P/N: 59377721
                  MO: AB03061403
                  I used the CH341A programmer to read the bios chips and afaik my laptop has 2 bios chips:
                  W25Q32FVSIQ and W25Q16DVSIG
                  I could read the ID of the W25Q32FV chip and it got detected by AsProgrammer, I'll attach the .bin file it created after I read the IC.
                  The problem I have is with the other chip W25Q16DV as no matter what I do it doesn't get detected by the program. I tried 2 different CH341A programmers and I get the same issue.
                  After connecting the programmer with the W25Q16DV chip and opening AsProgrammer I get this after pressing the read ID button:
                  ID(9F): FFFFFF(Unknown)
                  ID(90): FFFF(Unknown)
                  ID(AB): FF(Unknown)
                  ID(15): FFFF(Unknown)​
                  Also if I manually search for the correct chip and press the read IC button it only shows FF everywhere in the editor so I'm stuck at this and don't know what to do next.
                  Pressing the unprotect button only outputs "Old SREG: 11111111(0xFF)" with no new SREG and I'm not sure if that means that it's actively protected so I can't see any real output.
                  I bricked the laptop years ago and it doesn't power on on its own. After I connect the power supply to the laptop it appears to turn on, I can hear the fan spin and the LED for the power works but the display stays black.
                  Any help or advice is appreciated, thank you
                  • peste
                    • Dec 2016
                    • 12729
                    • ROMANIA
                    Lenovo G700
                    Model name: 20251
                    S/N: AB20185212
                    P/N: 59377721
                    MO: AB03061403
                    ID(AB): FF(Unknown)
                    remove the chip from the board before reading or writing, don't use the clip, you might have errors..
                    • markus24
                      • Jul 2024
                      • 6
                      Hey, I removed the chip from the board and I'm not sure what you mean with don't use the clip. So should I connect the chip with the CH341A programmer now that the chip is desoldered from the board?
                      • peste
                        • Dec 2016
                        • 12729
                        • ROMANIA
                        here is a video as an example...https://www.youtube.com/watch?v=DWWigscuQDY
                        • markus24
                          • Jul 2024
                          • 6
                          thanks, I used the .bin from hardware1 and soldered the chip back to the board. Does it look alright or should I resolder it again? I'm not sure how it's supposed to look like as it's my first time doing this
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11687
                            What's the hell going on ? What am I seeing ? The chip pins must be insulated from each other.
                            • markus24
                              • Jul 2024
                              • 6
                              As I said it's the first time I do this. I tried again, does this look okay?
                              • markus24
                                • Jul 2024
                                • 6
                                I got the laptop to work again!, for future reference:
                                I desoldered the W25Q16DV chip and used the CH341A programmer to flash the 2 MB .bin onto it provided by SMDFlea from post #5.
                                Then I resoldered the chip back to the mainboard and thanks to the input of hoaca388 I cleaned up the solder as you can see in post #15.
                                After that I connected the CH341A programmer with the W25Q32FV chip and flashed the 4 MB .bin onto it provided by SMDFlea from post #5.
                                I put the laptop back together and it worked again
                                I installed linux mint after I took the attached picture x)
                                Thanks to SMDFlea, peste and hoaca388 for the help!
                                • Macv
                                  • Mar 2025
                                  • 5
                                  Hi I need some help i have a lenovo g700 i want to change the wifi card but lenovo whitelisted certain stuffs in their systems anyone able to help me pls leave a response or message. thank you
                                  here is the file
                                • Macv
                                  • Mar 2025
                                  • 5
                                  serial number: 125031320011
                                    • 20781
                                    You posted some images, not your bios backup.... ,i think your serial number is wrong as well
                                    • Macv
                                      • Mar 2025
                                      • 5
                                      it won't let me post .bin or .rom files here so it's in the compressed folder
                                      • Wahaz
                                        by Wahaz
                                        10-30-2023, 08:42 PM
                                      • HammyCheesy
                                        Lenovo ThinkStation P720 BIOS Request
                                        by HammyCheesy
                                        Hello all,
                                        I'm trying desperately to revive a ThinkStation P720 that I purchased from a seller who claims it suffered a "failed firmware update."
                                        When given power, the machine turns on, spins up fans, beeps a single time, fans slow down, then a beep code is sounded repeatedly (3 high/short tones, 1 low/long tone).
                                        Type: 30BB
                                        Model Number: S03600
                                        S/N: MJ07N68C
                                        Things I have tried:
                                        1. Reseated all components, pulled everything except for 2 RAM modules (1 per CPU)
                                        2. Attempted to boot with just a single CPU...
                                        04-11-2025, 01:02 AM
                                      • grimacelord
                                        Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                        by grimacelord
                                        Hello there.
                                        I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                        History:
                                        1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                        I searched for this error online and discovered...
                                        03-15-2023, 03:29 PM
                                      • jbonavita
                                        by jbonavita
                                        Some issues
                                        Things I tried
                                        04-29-2025, 09:38 PM
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
