Razer blade crashes while updating bios and does not turn on
  • Patatas42
    • Mar 2021
    • 5
    • Spain
    Hi i need help whit one think,
    While updating the BIOS, windows crashed, the pc does not turn on, only the keyboard turns on the light and the screen does nothing. I guess if I restore the bios it will work, I have bought a CH341a programmer, but the problem is I can't find the bios chip on the board.
    The pc is a RZ09-03017GM2 (razer blade 15)
    Where is the bios chip ? whit this programmer i can recover my pc ??
    I bought the pc 10 days ago, I'm desperate
    Even if you don't know where it is, does anyone know what the chip is like?
    Thanks !!
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Razer blade crashes while updating bios and does not turn on
    next to PCH right side 6 legs IC if you bought the PC 10 days ago you should have the guarantee , to flash bios you need a tool do you have the skills to do it ?
    • Patatas42
      • Mar 2021
      • 5
      • Spain
      Thanks, I bought the used pc, not brand new, dont have guarantee...
      for that reason I need to fix it myself or the pc will be useless
      I need to know that there is any option, I have bought the CH341a programmer because I think it may be worth it, but I don't understand much about this
      If you could help me, I would really appreciate it
      EDIT:a photo of what I think is the PCH
        • 22312
        That is the bios chip,the one with the small bit of paint GD25B127. If your CH341A is the black pcb version it might need modifying. Check if its output is 5V ,if so then do the 3.3V mod - https://www.chucknemeth.com/usb-devi.../3v-ch341a-mod ,there are youtube videos too and lots of other info about the mod if you search.
        Did you get a sop8 clip with the programmer ? ,are you planning on using that or desoldering the chip ?.You can use a clip but your results may vary in getting a good read /write.
        • Patatas42
          • Mar 2021
          • 5
          • Spain
          Thanks!! Yes my ch341a is black pcb exactly this model https://www.amazon.es/gp/aw/d/B07RKX...b_b_prod_image
          Yes the programmer have a sop8 clip, i prefer use a clip for this, because if will be necesary i desoldering it
          I need one more thing, what is the program i will need for reprogram bios??
          Thanks Thanks thanks!!! ! !
            • 22312
            The CH341A software doesn`t support the GD25B127 ,use NeoProgrammer or AsProgrammer instead,although they don`t support it either you can choose GD25Q128 manually to read/write, and Neo/ASP is more stable software .Its recommended that you make 2 backups,check them with a hex editor to make sure theyre both the same, if not then atach the charger to the laptop then try again.If you can`t get 2 good backups then desolder the chip. The latest bios version is attached. Good luck
            https://www.badcaps.net/forum/showpo...04&postcount=7 NeoProgrammer
            https://www.badcaps.net/forum/showpo...6&postcount=10 AsProgrammer
            • Patatas42
              • Mar 2021
              • 5
              • Spain
              incredible, really, very grateful, tomorrow the programmer comes to me by amazon and I start with it, carefully and doing my best !
              When I'm done I'll write the result here, sure that's good
              I will use the AsProgrammer
              Thanks!!
              • Patatas42
                • Mar 2021
                • 5
                • Spain
                fixed up!!! This morning the programmer arrived, I made the mod, I verified the 3.3v, carefully I put the clamp, read the bios, made a copy, programmed the new bios and it is already working!
                Thank you very much for the help and advice, you are very great !!
                  • 22312
                  Great job, i`m happy you fixed it
                  • TheDonXR
                    • Jul 2022
                    • 4
                    OP any tips? I have the exact same issue that you had. Also just to verify the .bin file can be used as is? No need to make it a ROM?
                    • TheDonXR
                      • Jul 2022
                      • 4
                      I have the same issue as OP however I have a MX25L6436F installed on my MB which is not in the programming software. Any idea which one i could use to manually write to the chip?
                      • TheDonXR
                        • Jul 2022
                        • 4
                        Well nevermind, I was looking at the wrong chip after all, I had the sa me chip as OP, used the CH341a with the voltage mod and the clip to the IC. Read twice successfully, wrote the 1.04 update to the chip and I'm typing my reply on the RAZER. Thanks for this thread it really helped me out!!
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          Did you see a BSOD error? A software problem with the flasher or the BIOS chip is faulty.
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • TheDonXR
                            • Jul 2022
                            • 4
                            I got BSOD while the RAZER updater was halfway through the BIOS update so i couldn't boot into BIOS at all after the failed update. Used the CH341 and a clip to load the BIOS back to the chip (1.04 version for my model) then it booted and its running normally now.
                            • Heitor - AWS Informática
                              Razer Blade 2020 RZ09 03519E11 - BIOS Request
                              by Heitor - AWS Informática
                              Hi, everyone!
                              I've a Razer Blade 2020 on my bench today, all stand-by tensions are OK, but we've no action when I press the power button.
                              Here's some informations about the laptop and the original file backup:
                              Laptop Model: Razer Blade 2020
                              MB Model: ol510mb v1.0
                              P/N: RZ09 03519E11
                              S/N: 622048M10000619
                              Many thank's in advance! And if I broke any rule, sorry, I'm a rookie here, just tell me how can I fix that ...
                              Yesterday, 08:05 AM
                            • istvanszasz99
                              Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                              by istvanszasz99
                              Product Name: Razer Blade 15 (2022)
                              Product ID: RZ09-0421
                              Motherboard: CH580
                              BIOS Versions I work with: 2.02 & 2.06
                              Bios File Size: 32,768 KB
                              Dear Forum Readers!
                              I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                              I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                              The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                              !!! MY RAZER BLADE...
                              11-24-2025, 05:52 PM
                            • theplop
                              Razer blade 2022, 14" PI480 wont boot to OS, freezes
                              by theplop
                              Razer blade 2022, 14" PI480, Ryzen 6900HX, 16gb ram
                              I picked up a Razer blade 14" (2022) from a friend who said it "overheated" and he replaced one of the fans. He gave up on it as windows wouldn't work/re-install. He gave it to me, and i've been working on getting linux on it. Installing Mint i was able to get about 1/4 through the installer before it froze. Now i can't even get the installer to boot. I am met with a kernel panic.... sometimes. Sometimes it just hangs on the boot sequence.
                              I've run memtest quite a few times, and more often then not...
                              03-20-2025, 06:42 PM
                            • 0xx
                              2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
                              by 0xx
                              Hi folks,
                              My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
                              What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
                              I assumed that Windows Update was interrupted due to closing...
                              09-14-2025, 03:46 PM
                            • shellybelly
                              Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
                              by shellybelly
                              Back Story
                              I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
                              So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
                              08-27-2023, 10:40 PM
