cannot read/write SST25VF016B from HP620
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3636
    • slovakia
    Hello. I have RT809F. but i cannot flash/read SST25VF016B. when it verifiing it shows failure. tried another same ic but same failure.
    Tried another programmer butr still the same
    Laptop HP 620 caps lock beep one time
  • LatinMcG
    • Jun 2015
    • 73
    • USA/Puerto Rico
    Re: cannot read/write SST25VF016B from HP620
    try different SST chips 2MB from list then click Ok.
    is chip soldered with clip or on programmer adapter ?
    • CapThatBrass
      RT809F Chip Write Failure - Winbond 25R256JV
      by CapThatBrass
      I've managed to take an image dump in BIN format of my Dell Latitude 5420, which had a Winbond 25R256JV chip installed.
      I used an RT809F programmer to obtain the BIN, using the supplied iFix RT809F programmer application (latest version being 20220830).
      The programmer automatically found the settings to read the chip but selected the Winbond W25Q256FV instead (my actual model isn't available on the listing within the software). The image came out fine - I did this multiple times to clarify the data being read was the same each time.
      10-04-2022, 11:56 AM
    • ahmedtou
      HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
      by ahmedtou
      help me please
      I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
      When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
      I will share all the details with you, including the disc information.
      Code:
      HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
      Current Profile: BD-R
      Disc Information:
      Status: Empty
      State of Last Session: Empty
      Erasable: No
      Free Sectors: 12,219,392
      Free Space: 25,025,314,816 bytes
      Free Time: 2715:27:17 (MM:SS:FF)
      Next
      08-27-2025, 08:49 AM
    • npielawski
      MacBook Pro late 2016 (820-00239) with multiple failure modes.
      by npielawski
      I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
      I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
      10-15-2025, 01:53 AM
    • ChaosLegionnaire
      bug of the month: write caching setting for the hard drive in device manager
      by ChaosLegionnaire
      i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
      so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
      10-06-2019, 01:39 PM
    • vbogoev
      Lenovo S6000 won't turn on. Data recovery needed.
      by vbogoev
      Here I have the mentioned tablet with motherboard s6000-mb-h401. The tablet won't turn on, no display, charging normally. I manage to connect to UART port and got this output when I try to start it:
      Code:
      [PWRAP] pwrap_init_preloader
      [PWRAP] pwrap_init
      [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=0 rdata=5AA5
      [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=1 rdata=5AA5
      [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=2 rdata=5AA5
      [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=3 rdata=5AA5
      [PMIC_WRAP]wrap_init pass,the return
      06-20-2023, 06:36 AM
