Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
ASUS TP412UA BIOS Request
  • vieuxchoub
    • Oct 2017
    • 34
    • france
    Hi friends!!!
    This is the original bios bin file that I have extracted with my TL866 programmer..... Could someone tell me if this bios works correctly???? On the net, all the bios available are pay for.....
  • hdd00
    • Jan 2015
    • 32
    Bios for Asus TP412UA
    Hi
    I need a working bios dump form an TP412UA.....The reading from original bios chip resulted in a almost empty dump (almost full of FF's). Tried reading several times , still the same result.
    Rgds
    • vieuxchoub
      • Oct 2017
      • 34
      • france
      Re: Bios for Asus TP412UA
      Dear hdd00
      I attach the .bin reading of my TP412UA bios... This bin file seems correct through UEFI Tool but my TP412UA is dead: charging light but no reaction to the power button.... I have changed the SIO ITE 8987E chip with no luck... I would appreciate that you give a feedback for bios bin file: does it work on your TP412UA????
      • vieuxchoub
        • Oct 2017
        • 34
        • france
        Hi friend hdd00!!!!
        Does my TP412UA bios dump work, please???? Best regards
        • sikocan
          • Oct 2019
          • 351
          ASUS TP412UA BIOS Request / Help with UEFI Tool
          Hi all and thank you for your help so far. Please I have 2 requests and 2nd is more important then the first.
          1. Request for BIOS for ASUS TP412UA Motherboard.
          Attached are 3 files related to it:
          File 1 is Dump from original BIOS.
          File 2 is I've cleaned the Intel ME region from my Dump.
          File 4 is Downloaded BIOS from ASUS website to make it easy for you.
          2. Request is I've tried to open the File 4 from above in UEFI Tool and attempted to hopefuly export the BIOS region however I can only see "UEFI Image" instead of "Intel Image" as you would with cleaned ME region BIOS or from a Dump. So I've used a Hex Editor to trim down to match both header start and ending to the cleaned and the dump version but I wasn't able to trim it further and wouldn't fit in the BIOS as it was refused by the programmer. I use Raspberry Pie to the programmings using flashrom utility. My request is how can I in the future integrate the BIOS from file ASUS website and into my Dump or generate a BIOS file from ASUS's website.
          For this purpose I've attached my trimmed down version of the BIOS file which is File 3, but it's too long. I also make YouTube videos and your help will help me produce the content so others can benefit.
          Original fault of the machine for your reference, it turns on and nothing else. It charges battery. No backlight. Caps lock / num lock light when pressed. From watching the fan very closely I can sort of see a loop where it ever so slightly slows down and goes faster again, but faintly, unless I'm imagining.
          All voltages are there except Coil Marked on the attached board image which Resistance to ground reading is just above 3 Ohms which I suspect is normal.
          Under thermal camera all look good nothing out of ordinary. CPU does start to get warm over time which is normal hence the fan spinning afterwards.
          Thank you in advance.
          • sikocan
            • Oct 2019
            • 351
            Re: ASUS TP412UA BIOS Request / Help with UEFI Tool
            An update if this may help anyone, here is a data log of the state of the BIOS when:
            Charger is plugged in, up to 30 seconds of recording, here is the video:
            https://youtu.be/4coosr-iv38
            When the Power button is pressed. Up 2 minutes of recording, here is the video:
            https://youtu.be/iL4g55wsEIA
            • sikocan
              • Oct 2019
              • 351
              Here's the setup pics.
              • peste
                • 14711
                • ROMANIA
                try..
                • sikocan
                  • Oct 2019
                  • 351
                  Hi peste, this had a different effect and still did not work. What happenes is this:
                  Turn On
                  Few seconds, Turn Off.
                  Turn On,
                  Turn On. Stay on more than 3 minutes then while staying ON, yellow (amber) light starts flashing non stop. There is no pattern to the Yellow light, just keeps going on and off in a timely fashion, maybe every 1 second.
                  Same behaviour with SSD inside or out. Same behaviour with or without battery.
                  I suspect the issue is related to that COIL which has no power. I'm going to remove it and turn it on see if the MOSFET next to it will supply power to 1 leg of coil. If not, I'll go backwards and work on the mosfet/gate situation.
                  I wonder if there is a way to disable onboard RAM - usually you cam move some resistors around but not sure about this particular model on which and how to.
                  • sikocan
                    • Oct 2019
                    • 351
                    Re: ASUS TP412UA GPU or CPU not turning ON
                    Bios flashing fixed. Found one on the net, it worked but 30 sec delay and didn't detect ram. I have fixed those in the attached cleaned me region for others to use.
                    • hdd00
                      • Jan 2015
                      • 32
                      Hi....
                      Unfortunately I don't have the laptop anymore.......When I will receive an identical laptop I'll let you know.
                      Rgds
                      • jobe
                        • Jul 2016
                        • Israel
                        works great! thanks!
                        • Dinneke
                          • Apr 2014
                          • 154
                          • Netherlands
                          Ask for HDD pasword, any ideas?
                          • tH0RiN
                            • Apr 2016
                            • 6
                            • España
                            Works Perfect!!
                            • tek444
                              • Feb 2022
                              • italy
                              @sikocan
                              sorry if resume this thread a little bit old, so i flash your bios but the same...no video, white led always on, i don't understand if you have changed some components or not, thank you
                              • peste
                                • 14711
                                • ROMANIA
                                Originally posted by tek444
                                @sikocan
                                post the original bios of the laptop..
                                • tek444
                                  • Feb 2022
                                  • italy
                                  Hi peste, unfortunately, like a stupid, I didn't save the old bios and I understood only after that I lost important information....
                                  • tek444
                                    • Feb 2022
                                    • italy
                                    A question: some year ago windows update ask me to update the system firmware (bios) i make the update but there's a chance that this procedure save the old bios?
                                    • peste
                                      • 14711
                                      • ROMANIA
                                      post it as corrupt as it is and clear pictures with the white or green stickers from the ram memory area..
                                      • tek444
                                        • Feb 2022
                                        • italy
                                        maybe I wasn't clear, I overwritten the old bios with the bios "Holigrail" from Sikocan flashing with the CH341A
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                        • ronaldopdias
                                          ASUS ROG Strix B660-I Gaming WiFi – BIOS dump vs ASUS CAP size mismatch, need corruption check, please.
                                          by ronaldopdias
                                          I’m troubleshooting an ASUS ROG Strix B660-I Gaming WiFi motherboard and I’m a bit stuck at the BIOS level. What I’ve tried so far
                                          • Attempted to flash the BIOS using the USB BIOS FlashBack (Q-Flash) port with a properly formatted FAT32 USB drive.
                                          • BIOS file downloaded directly from the official ASUS support page.
                                          • Followed the exact FlashBack procedure (correct port, renamed file, standby power only).
                                          Issue:
                                          The FlashBack LED does not blink at all — no activity whatsoever. Further investigation
                                          Because FlashBack didn’t work, I:
                                          • Removed the BIOS SPI IC from
                                          02-04-2026, 03:16 AM
                                        • gandamonteiro
                                          ASUS A407UB (36AM1SB1) Rev 2.0 – Full 8MB BIOS Dump Request
                                          by gandamonteiro
                                          Hello.
                                          I am looking for a FULL 8MB BIOS dump for:
                                          ASUS A407UB
                                          Board: 36AM1SB1
                                          Rev: 2.0
                                          The laptop has no 3.3V rails after a bad BIOS flash.
                                          Originally the board powered on abnormally (CPU heating as soon as adapter was plugged).
                                          After flashing an incomplete BIOS image, the board is now dead (no 3.3V, no boot).
                                          What was tried:
                                          - Read BIOS guides and recovery methods
                                          - Used official ASUS BIOS file (partial image)
                                          - Tried flashing with external SPI programmer
                                          - Recovery was not successful
                                          Request:...
                                          12-21-2025, 09:01 AM
