Need LA-E991P Rev 1.0 (A00) Bios.
  • ProSis
    • Jun 2017
    • 87
    • Turkey
    I could not get an image in the bios I found or I had the following problems. I would appreciate if anyone can help with this. Thanks already.
    When the device displays an image, it displays as "manufacturing mode on alt + F".
    When I switch to normal mode with Alt + F, the image disappears and does not return.
    When I enter and save the "service tag" information by logging into the bios, it does not display any more and it turns off after a few seconds, pulling around 1.10A.
    Org Backup
  • peste
    • 13924
    • ROMANIA
    Re: Need LA-E991P Rev 1.0 (A00) Bios.
    Org Backup
    post the full name and model of the laptop.
    • ProSis
      • Jun 2017
      • 87
      • Turkey
      Inspiron 15 Gaming 7577
      P72F001
      • peste
        • 13924
        • ROMANIA
        P72F001
        try..
        • ProSis
          • Jun 2017
          • 87
          • Turkey
          try..
          I took an image with this file.
          There is only a problem like this, when I first plug in the adapter and turn it on, the image appears. As long as the adapter is plugged in there is a picture every time.
          but when I unplug the adapter and plug it in, I start it at around 1.30A and it shuts down.
          When I remove the bios battery and plug in the adapter again, the image comes out, and when I remove and plug the adapter, it does not come back.
            • 22293
            Check CMOS battery voltage
            • ProSis
              • Jun 2017
              • 87
              • Turkey
              I just plugged in the situation is the same. When the adapter is disconnected and attached, it does not display.
              • ProSis
                • Jun 2017
                • 87
                • Turkey
                I installed a new battery the situation is the same
                • DynaxSC
                  by DynaxSC
                  06-14-2024, 03:49 PM
                  by Vesko356
                  08-11-2023, 03:27 AM
                • grimacelord
                  Latitude E6530 - Trouble Extracting BIOS Image From EXE
                  by grimacelord
                  Hi folks,
                  I'm having a hard time extracting this Dell BIOS. I have a Dell Latitude E6530 that has BIOS corruption and I need to reflash with CH341A programmer. I have already taken dumps of both the 4MB and 8MB chips on the motherboard.
                  Service tag number for this model is: "JYDWYW1".
                  Link to latest BIOS for this Service Tag: https://dl.dell.com/FOLDER05371360M/1/E6530A22.exe
                  I have tried:
                  • Simply extracting with 7zip
                  • PFSExtractor
                  • Using "/writeromfile, /writehdrfile, and /writehexfile" commands
                  • Check Temp folder
                  10-26-2023, 08:15 AM
                • istvanszasz99
                  Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                  by istvanszasz99
                  Product ID: RZ09-0421
                  Motherboard: CH580
                  Bios File Size: 32,768 KB
                  Dear Forum Readers!
                  !!! MY RAZER BLADE...
                  11-24-2025, 05:52 PM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
