Dell Precision 5520 bios password
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ---------------------------------------------------------------------------------------------------------------------------------------------------------------- -
Re: Dell Precision 5520 bios password
plz remove the passwordAttached FilesComment
hi I have dell precision 5520 with bios locked.
The tag is J784SN2-6FF1
I tried using the password :
Dell from serial number c31Mw60CfMGHcncH
which I got from: https://bios-pw.org/
I also tried several other options from another password website but to no avail.
Would someone help me unlock it please?
Thank youComment
Thank youLast edited by hoaca388; 07-10-2022, 03:33 AM.
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
TryAttached Files
Hi, i have Dell Precision 7710 service tag 6X5PN72-6FF1. I tried passwords from bios-pw.org many times but it didn't work...plz help meComment
yes...it suggested changing suffix to BF97, i did that too but not workingComment
It won't work if you type that in lower case, i was making that mistake, then i thought let me give it a try in upper case & it worked instantly.
PS: I used UK keyboard, conclusion is it doesn't matter which keyboard you use as long as you type it correctly...Comment
Good morning
Well, it depends on the characters of the master password.----------------------------------------------------------------------------------------------------------------------------------------------------------
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Channel: BIOS Requests ONLY!
by trix11I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
- https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
- Dell Precision T1650 mid tower Workstation
- Xeon E3-1225 V2
- 32Gb PC3-12800E RAM
- 4Tb SATA HDD
- motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
I see now that others have experienced like issues e.g.:
- https://www.dell.com/community/Prec...-
by markenero3Good Day Everyone please help! I have Dell precision 3480 13th gen with Bios password and absolute enable. I already tried 8FC8 Patcher it works but the absolute still cannot be disabled
Here is my Orig bios file with Bios password and Absolute Enabled
Board: IDB40 LA-M402P
Service Tag : HFZW724
Thank you So much in advance....-
by bmxlovahHi,
My Dell Precision T7910 died after enabling onboard SAS controller and applying RAID settings. There were no hardware changes between working and not working state, only setup (via bios -> controller settings). After applying settings and reboot PC turns on, flash leds (normally) but there's no further action, it just stays on with no graphics and no keyboard led's on. There's no Dell logo, nothing. I've tried resetting bios by jumper, replacing cpu's, replacing ram, removed/replaced cmos battery, disconnecting all drives etc. I've also dumped .bins from mobo chips SLI1 (16...-
by cozilyI bought a DELL Precision 3660 Tower Workstation from a second-hand seller. After bringing it home, I found out it was actually a testing unit. The BIOS cannot be upgraded (only the ME and PD2 sections are upgradable), and there are test messages displayed during boot, which really affects the user experience.
Upon inspecting the motherboard, I noticed that the BIOS is composed of two chips: one 8-pin 16MB chip and one 16-pin 32MB chip.
I acquired two new chips from another source containing the official BIOS version, but after installing them, I found that none of the...-
- Loading...
