Panasonic Toughbook CF-C2 please remove bios password!
  • Andreasbest
    • Aug 2014
    • 1142
    • Hellas ( Greece )
    Thank you in advance!!
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1192
    • France
    Re: Panasonic Toughbook CF-C2 please remove bios password!
    try clear
    • Andreasbest
      • Aug 2014
      • 1142
      • Hellas ( Greece )
      It still asks for password.
      How is this possible? You deleted the 5B after AMITSESetup and still asks for password?
      • RethoricalCheese
        • Mar 2013
        • 1517
        • Estonia
        This will work
        • Andreasbest
          • Aug 2014
          • 1142
          • Hellas ( Greece )
          Originally posted by RethoricalCheese
          This will work
          I see the only change is 00000070 byte 0A changed from FF to 00 but didn't work either.
          How is that possible?
          • RethoricalCheese
            • Mar 2013
            • 1517
            • Estonia
            Oh, well, that was a typo anyway.
            I don't see a reason why this wouldn't work.
            • Andreasbest
              • Aug 2014
              • 1142
              • Hellas ( Greece )
              Well except that byte the rest of the .bin is exactly identical with the Maxpower3 .bin.
              Is there any default password that appears when you remove all batteries, psu and rtc?
              What do we miss?
              • Andreasbest
                • Aug 2014
                • 1142
                • Hellas ( Greece )
                I have news.
                With your (both) .bin i'm able to enter bios and change everything, except the supervisor password.
                Seems like the password is stored to another location of bios too.
                • Andreasbest
                  • Aug 2014
                  • 1142
                  • Hellas ( Greece )
                  I have more news, my bios seems like it's modified to restore several settings when "load defaults" and also a Panasonic supervisor password that set as default.
                  Here is the link with info regarding bios ending with M like mine (M10) https://customrugged.com/m-bios-panasonic-toughbook/
                  So there is indeed a bios password elsewhere inside dump stored by Panasonic, probably in "default settings" section of bios.
                  • Andreasbest
                    • Aug 2014
                    • 1142
                    • Hellas ( Greece )
                    Searching with UEFItool meanwhile
                      • 20412
                      Try this one
                      • Andreasbest
                        • Aug 2014
                        • 1142
                        • Hellas ( Greece )
                        Thank you SMDFlea but i just bought a clean bios dump from a site, unfortunately none gives it for free.
                        Anyway, i managed to enter bios, supervisor passwords are clear and everything can be modified BUT
                        if i do "load defaults" the password returns and i must reflash the bios.
                        So these "defaults" are stored in bios chip itself OR somewhere else?
                        I suspect that this thread will become a guide for anyone that buys M bios Toughbooks.
                        • Maxpower3
                          Bad Veteran
                          • Feb 2018
                          • 1192
                          • France
                          you tested "toughbook" or "panasonic" as the default password?
                          you can share us your file which works in mp
                          • Andreasbest
                            • Aug 2014
                            • 1142
                            • Hellas ( Greece )
                            I tried "toughbook", "panasonic" and "password", none worked.
                            here is the file that worked too.
                            Please compare it to found out where is the supervisor password stored in my backup.
                            Although i have serious reasons to believe that is stored elsewhere than the bios chip since it's a M model like i said before.
                              • 20412
                              Did you try setting a new password rather than setting bios defaults. Theres another password for the Optional Kit Configuration: toughkit
                              • Andreasbest
                                • Aug 2014
                                • 1142
                                • Hellas ( Greece )
                                With the bios you all sent me i cannot since the bios detects there is already a supervisor pw and offers only change pw option, impossible because i don't know the pw.
                                With the bios i bought i can set a supervisor pw that works, unless i do "load defaults" then changes back to the unknown supervisor pw.
                                "toughkit" doesn't work either.
                                Panasonic did terrific job in this i have to admit.
                                  • 20412
                                  Are you tring without the HDD attached. Post a picture of the pass screen.I doubt its stored in the EC ,what is the EC chip ?
                                  Edit: did you remove the CMOS battery and clear it by shorting the battery pins for 20 seconds or so ?
                                  • Andreasbest
                                    • Aug 2014
                                    • 1142
                                    • Hellas ( Greece )
                                    Yes i try without HDD
                                    The screen is the usual Toughbook password screen.
                                    Yes CMOS battery is detached from the beginning, no power on MB except the PSU when i plug it.
                                    I also tried 20secs short circuit.
                                    Well i'm almost convinced is stored into EC.
                                    • Maxpower3
                                      Bad Veteran
                                      • Feb 2018
                                      • 1192
                                      • France
                                      what is that? maybe
                                      • Maxpower3
                                        Bad Veteran
                                        • Feb 2018
                                        • 1192
                                        • France
                                        if you put the bios it's ok but when you restart you ask for the password again. is that correct?
                                        you can read bios after restart and ask for the password too
