Lenovo X1 Carbon 7th Gen 20QD Bios
  • davem12
    • May 2019
    • 11
    I am looking for a Bios file for a Lenovo X1 Carbon 7th Gen Type 20QD. The one I am trying to repair had a failed bios update and was corrupted and will not post.
    Thank You
  • peste
    • Dec 2016
    • 13436
    • ROMANIA
    Re: Lenovo X1 Carbon 7th Gen 20QD Bios
    Thank You
    if you still have it, post it as corrupt as it is ..
    • davem12
      • May 2019
      • 11
      I found the W25Q256JVEQ Bios chip. It is a 8-WDFN Exposed Pad type chip. How do I connect to it and read it?
      Sorry for the newbie questions. I never came across one of these chips.
      • FELIXSANTOS
        • Mar 2022
        Any update?
          • 21679
          Originally posted by FELIXSANTOS
          Any update?
          Any update about what ? .If you want help say so,and post your bios backup. What problem are you having
          • FELIXSANTOS
            • Mar 2022
            Thinkpad X1 Carbon GEN 7 (20QE) BIOS NEEDED
            I have a dead black screen after a unsuccessful BIOS update.
            I wanna trie to reprogram the BIOS using a CH341a programmer.
            But I was not able to find the files.
            Help pls.
              • 21679
              Re: Thinkpad X1 Carbon GEN 7 (20QE) BIOS NEEDED
              Help pls.
              I have sent you a PM with a link to the rules.. .Post your backup,it doesn`t matter if its corrupt.Also post the serial number on the case
              • hoaca388
                Badcaps
                • Jan 2022
                • 12272
                Solder the wires to the chip pins
                • 3mz3t
                  • Sep 2023
                  • 13
                  • Slovakia
                  ThinkPad X1 Carbon Gen 7, type 20QD, S/N PF-21V10Z
                  The notebook starts & lights up, but screen is blank (although I tested it works), no POST.
                  Maybe ME clean required?
                  Thank you for your help.
                  • 3mz3t
                    • Sep 2023
                    • 13
                    • Slovakia
                    In my previous post I attached the uncompressed bios dump (i.e. it's not a zip file). Sorry about that.
                    • kalilinux25
                      • Mar 2018
                      • 2089
                      • ZAMBOANGA SIBUGAY
                      please reupload you rar file its corrupted I cant extract
                      • 3mz3t
                        • Sep 2023
                        • 13
                        • Slovakia
                        Yep, here's the zip file with the bios dump.
                        Thanks.
                        • kalilinux25
                          • Mar 2018
                          • 2089
                          • ZAMBOANGA SIBUGAY
                          Thanks.
                          what is the motherboard code that is printed to it.
                          is it FX490 NM-B861 REV 1.0 ???
                          • trunguntilyou
                            • Aug 2022
                            • 355
                            • Vietnam
                            Need bios, when the machine turns on it shows error 2202 invalid machine name and 2200 invalid machine configuration, while the machine information still matches
                            sn PF-14N29Q
                            • volinakis
                              • Jan 2021
                              • 2872
                              • N/A
                              sn PF-14N29Q
                              use Lenovo maintenance utility to write DMI in EC. You'll find B0 to a label from motherboard (8S....) , C0 is 1S20QD000LUSPF14N29Q and brand name is ThinkPad X1 Carbon Gen 7
                              • trunguntilyou
                                • Aug 2022
                                • 355
                                • Vietnam
                                The device information still matches, I used that utility to delete and rewrite it but it didn't work, I loaded another bios and the notification went away but the update was very slow but I tried clearing me but the power didn't work.
                                • trunguntilyou
                                  • Aug 2022
                                  • 355
                                  • Vietnam
                                  Oh,, luckily I managed to clean the bios
                                  • da_n0n3
                                    • Sep 2024
                                    • 5
                                    • Switzerland
                                    Hi Guys
                                    My Laptop most likely bricked my laptop after Bios Update...
                                    Resetting no success.
                                    Now i took out the bios chip (25Q256JVEQ) and read the bios in the RT809F ISP Programmer (?correct?).
                                    I did two readings, please look at the attachments.
                                    Can may be someone provide me with a working bios to flah on... as a last resort chance...
                                    model : Thinkpad X1 Carbon 7th Gen
                                    motherboard: FX490 NM-B861 Rev: 1.0 (2019-03-28)
                                    serial number: PF-1RWX6S (19/07)
                                    typre number: 20QD-003AMZ
                                    many thx
                                      SMDFlea commented
                                      Editing a comment
                                      Thread merged with existing topic.
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12272
                                    Originally posted by da_n0n3
                                    Hi Guys
                                    many thx
                                    X1 Carbon 7th Gen - Laptop (ThinkPad) - Type 20QD
                                    • da_n0n3
                                      • Sep 2024
                                      • 5
                                      • Switzerland
                                      THX hoaca388, the provided BIOS.BIN worked perfectly.
                                      had to perform several attempts to flash the BIOS.BIN to bios-chip (RT908f Programmer).
                                      Can further use the Laptop.
                                      • TylerHyde21
                                        Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
                                        by TylerHyde21
                                        Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
                                        I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
                                        I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
                                        This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
                                        06-29-2024, 10:38 AM
                                      • MaxonDomkrat
                                        Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
                                        by MaxonDomkrat
                                        Hi everyone.
                                        I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
                                        07-30-2025, 01:27 PM
                                      • lucaszmn
                                        by lucaszmn
                                        Problem:
                                        Initial Findings:
                                        • I concluded that the
                                        08-12-2025, 03:01 PM
                                      • Wahaz
                                        by Wahaz
                                        10-30-2023, 08:42 PM
                                      • grimacelord
                                        Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                        by grimacelord
                                        Hello there.
                                        I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                        History:
                                        1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                        I searched for this error online and discovered...
                                        03-15-2023, 03:29 PM
