Dell G3 15 3500 bios help
hello every one
i have dell g3 15 3500
mainboard Selek g3 mlk n18p 19795-1 403yf$ja
reg type:p89f003
thats all details i have s/n and service tag are removed
it had short circuit on gpu mosfet
after replacing it came to life but stuck on logo
tried whith to flash another ec.bin it worked but fan are very loud and it shut down after afew minute
can any one fix my ec bios
i uploded both ec and main
best regardsLast edited by amr soliman; 01-21-2025, 01:50 PM.Leave a comment:
I have a problem with my Dell G3 laptop.
Service Tag: JS3GF63
The CPU fan was not working at all and the GPU fan was running at full speed.
After uploading both files from post nr 190 in this topic on a trial basis, the fans both run at full speed, you have to wait several seconds for the logo and the Service Tag cannot be saved.
I tried clearing ME, but FIT can't open the file.
If it is not possible to fix my bios, I would ask you to add the Service TAG to the one in post nr 190
Thank you!
Service Tag: JS3GF63Attached FilesLeave a comment:
Thank you!Attached FilesLeave a comment:
Thanks a lot, hoaca388, for your help.
Just giving the feedback, it hapenned the same thing as the other bios I tested (black screen and fan too fast).
I am starting to think that it is not a bios problem.
I apreciate your help anyways!Leave a comment:
Sorry, I changed the post, this is the correct one.
Below is the same post:
Thanks HOACA388 for your help.
But the notebook is still working with a black screen.
I've writeen both BIOS. When connecting the power supply or internal battery, the laptop starts, caps lock turns on, blinks twice, after a few seconds it turns off and then restarts the cycle indefinitely.
I waited 30 minutes when turning it on for the first time. The fans is working normally now but the keyboard is inoperative. The power led lights up for a few moments.
I would appreciate any help.Leave a comment:
Hello, friends.
I need some help with my Dell G3 15. I´m having black screen, restarts and the fan is too fast with other bios I tested.
If possible, restore original bios or one that works properly.
Bellow are the original bios.
Thanks in advance!
Service Tag: HNL2RD3
Service Tag: HNL2RD3Attached FilesLeave a comment:
Service Tag: 6HMQ0D3Attached FilesLeave a comment:
Hello, friends.
Thanks in advance!
Thanks Shiyab, I tried both but they won't work, laptop won't turn on.
In fact this was the initial defect.
With others bios that I tested the laptop turns on and fans at max speed.
I opened both (8MB - original and sent) with ME Analyzer 1.304 and they show errors (attachments).
I still need help!!Leave a comment:
DELL G3 15 3500 - SELEK 19753-1 Service Tag: 6HMQ0D3
It worked normally, after testing it turns on but no display, fans works at max speed.
I tested others bios without success.
Please help to fix my bios files.Attached FilesLeave a comment:
Hello, friends!
Need some help with my dell g3.
Black screen, restarts and the fan is too fast with other bios I tested.
Appreciated in advance!Attached FilesLeave a comment:
hi try both file flashAttached FilesLeave a comment:
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
by mrrubikHi folks,
I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
Steps I took:- Read BIOS with CH341a, verified hash twice
- Patched
- Loading...
