Asus x202e need to fix bios
  • String2016
    • Nov 2015
    • 2229
    • philippines
    Can someone please fix this bios please
    • 20633
    Re: Asus x202e need to fix bios
    use the forum search.... https://www.badcaps.net/forum/showth...ighlight=x202e
    • String2016
      • Nov 2015
      • 2229
      • philippines
      already tried that bios but the laptop is not turning on unlike original turns on at full speed
        • 20633
        Clean your original ME region .
        • String2016
          • Nov 2015
          • 2229
          • philippines
          @smdflea can you please fix this file please
          • peste
            • 12582
            • ROMANIA
            try..
            • String2016
              • Nov 2015
              • 2229
              • philippines
              still same issue
              • String2016
                • Nov 2015
                • 2229
                • philippines
                update i reflash the original with new chip its working but i need to reset cmos battery in order to boot up
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • grimacelord
                  by grimacelord
                  07-10-2025, 02:52 PM
                • throwaway327
                  by throwaway327
                  Model No: RC72LA
                  Serial No: SBNVKD001014459
                  06-18-2025, 05:52 PM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • lrouw84
                  Asus vivobook s510ua bios changed to x510un
                  by lrouw84
                  Hi there,
                  I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                  I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                  01-28-2023, 01:31 PM
