hp 450 g7 password
  • ZBeeblebrox
    • Oct 2013
    • 14
    Re: hp 450 g7 password
    Okay, at the risk of throwing this thread completely off topic, here's what I've found about the Absolute software:
    I reset the security settings in BIOS and wiped the drive with EaseUS Partition Master, as suggested. I then reinstalled Windows 10 with no internet connection. On first start, Absolute software was installed in the Windows folder, I assume by the BIOS. The files were "rpcnetp.exe", "rpcnetp.dll", and "wpbbin.exe", located in the System32 and SysWOW64 folders. "Rpcnetp" also ran as a system service. I stopped the service, and deleted the rpcnetp files (before I found that wpbbin was also an Absolute file), but those files reappeared after a reboot. I then created dummy files (0kb txt files renamed as .exe and .dll) and placed them in the proper locations, after killing the service/running process, and setting the dummy files to read-only. The software did not reactivate after reboot. I then ran Windows Update, and all updates installed without creating the Absolute Software or CTES folders that were installed on first Windows try. It's been running for several hours now without installing the Absolute software or entering "Device Freeze" mode. I haven't tried Windows update without creating the dummy files to disable rpcnetp/wpbbin, so I don't know for sure yet if resetting the Security Defaults in BIOS would have really set Absolute to not install by default, but I will test that in the near future, now that I know how to disable it. I can only assume the software uses the UUID or serial number to check the status, regardless of the persistence module state. I can say that the Device Freeze and Absolute installation does not change the module's inactive state or re-enable it, as the BIOS setting remained permanently disabled even after previous Windows install and Device Freeze. Thanks again for your amazing help with this, and hopefully this info may help anyone dealing with this in the future.
    • Throwaway900
      • Dec 2022
      • 7
      Hi. I was following what people said here and tried unlocking some HP's. So I ran into a problem with one of the laptops, a Probook 450 G7. I thought everyone said it has a 32mb and a 16mb SPI and to onlydo the 16, so I found a chip(25B127DSIG) that was 16MB, I backed it up and then ran the tool, flashed it and the password was gone. But then I had an error for the Security controller. And all the hardware ID's seemed to be gone. I realized looking closer that I had flashed the EC. So i restored the backup image I took but continue get the security controller error, So i found the second SPI(25L12872F?) and dumped that, it looked like what i expected from the BIOS and it actually gave me hardware details so I unlocked that and flashed it back, and then reflashed the EC with it's original backup I took. However while the hardware ID's were fixed, I continue to get security controller errors. After each attempt I have reset security to defaults, entered the code it gives, F1 to clear TPM, and even tried reflashing the BIOS from inside windows, but I continue to get the controller error. Any help would be appreciated.
      I have included the "original dumps" although the EC was taken first, i messsed it up, and then backed up the bios, My fear is when I flashed the ec and powered it up, something was changed in the bios chip too and because of that I now have managed to screw up the states between the two and cannot easily get them synchronized again. Im only including the original dumps to try and keep it clean. Hope someone can help
      • hardware1
        • Sep 2021
        • 2948
        • N/A
        #103
        Here's your Unlocked BIOS, Program both files together. In the first boot go to BIOS Menu and disable security options (Default).
        You must fill your DMI manually.
        all donations are welcome,
        • Throwaway900
          • Dec 2022
          • 7
          I will try this Monday or Tuesday. What is the best way for me to fill in the DMI? Thanks for the speedy response!
          • hardware1
            • Sep 2021
            • 2948
            • N/A
            #105
            There's a tool from HP called "BIOS Configuration Utility" (BCU), you can find a lot of videos on Youtube for it.
            • Throwaway900
              • Dec 2022
              • 7
              Thankyou very much again!
              • Throwaway900
                • Dec 2022
                • 7
                Hi, just letting you know I flashed both your files and the laptop now won't boot, the numlock and caps lock flash occasionally and the wireless/micmute stay lit. it will powercycle every 15-30 seconds and repeat. I haven't flashed back the originals yet but both chips verified with your flashes
                • Throwaway900
                  • Dec 2022
                  • 7
                  Didn't realize I can't edit replies. I reflashed the original BIOS and EC, and laptop boots again but with the error same as before(as i would expect).
                  Ugh
                  • ogre4273
                    • Mar 2022
                    • 57
                    • N/A
                    #109
                    Originally posted by Vesko356
                    You can try setting both "Permanent Disable Absolute Persistence Module Set Once" to "Yes" and "Absolute Persistence Module Current State" to "Inactive" at once via BCU then restart and enter the bios to see if it's changes, just go ahead and experiment with different options, if something go wrong you can always reflash Winbond chip and start all over.
                    Yes.
                    @Vesko356
                    Can I brick my laptop if I do this? Btw, I successfully obtained the config for my laptop and did what you mentioned. I'm having second thoughts as to setting the config because I was worried I might brick my pc. Thanks
                    • Vesko356
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      #110
                      Originally posted by ogre4273
                      @Vesko356
                      I do not think so. But in order to succeed in what you are aiming for, the machine must be in mpm active mode.
                      Become a Badcaps supporter
                      Thanks to all supporters.
                      • ogre4273
                        • Mar 2022
                        • 57
                        • N/A
                        #111
                        in config.txt i saw MPM mode on lock, should I unlock it and proceed?
                        • Vesko356
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          #112
                          You can try yes, but I don't think it will work out. Your bios should be modified first to activate MPM mode, and then you will be able to make changes with the BCU. I'm talking about disabling Absolute if that's your goal.
                          • Throwaway900
                            • Dec 2022
                            • 7
                            Anyone maybe able to help me take a look at my bios one more time?
                            • kubat
                              • Jan 2023
                              • 21
                              • Киргизия
                              #114
                              Hello! Help me please. I saved dump both bioses incorrectly and now I don't have the original bios (they have them but they are corrupted, I will add them to the message). Can you give me both any perfectly working bios with cleared MPMs? Or fix my original bios with password clearing?
                              • elniñodelcautin
                                • Jul 2023
                                • 18
                                • bogota
                                #115
                                here the bios file without absolute, delete all the information from the ssd or hdd before, deactivate the bios security options when entering the bios for the first time and save changes after you have a clean installation of the operating system and that's it you can update without problem
                                • kubat
                                  • Jan 2023
                                  • 21
                                  • Киргизия
                                  #116
                                  Hello my dear friend! I flashed this bios, but when I turn it on, there is an error, and the MPM is locked. And the inclusion is long.
                                  • elniñodelcautin
                                    • Jul 2023
                                    • 18
                                    • bogota
                                    #117
                                    Ugh
                                    What is the error you have with the original bios?
                                    • elniñodelcautin
                                      • Jul 2023
                                      • 18
                                      • bogota
                                      #118
                                      Greetings, colleague from the soldering iron
                                      you have to reprogram the two bios, the gigadevice unlocked that I published and the original winbon, it has to be like this to avoid errors since they are matched in information, please program the two chips before the first ignition, remember that the first ignition takes several minutes, (observation) if the power is completely removed, the equipment will take minutes to turn on again
                                      comment if it worked for you
                                      • kubat
                                        • Jan 2023
                                        • 21
                                        • Киргизия
                                        #119
                                        Hello! I flashed both bios. There are no errors when turn on. MPM is lock, BCU utility cannot unlock it. Absolute program has not yet tried, but the blue screen sometimes appears. How i can unlock MPM? I need change: serial, SKU, CT, UUID, MAC.
                                        • elniñodelcautin
                                          • Jul 2023
                                          • 18
                                          • bogota
                                          #120
                                          Your bios does not have an absolute activation, your bios does not have a password if they are the original bios I do not understand why you want to change the bios information, regarding the blue screen do a clean installation of windows if it persists do a bios update or a recovery mode to repair the bios in case you have a problem if the problem persists clean the me region of the WINDBOND bios
                                          • AppleLover123
                                            Lenovo Yoga X380 22LH Supervisor Password removal
                                            by AppleLover123
                                            Hey guys,
                                            have a laptop here that has a supervisor Password (dump in Attachements).
                                            Before i write the Serial NR.etc i wanted to say that strangely after flashing with 3 different Bios dumps and one from lenovos site
                                            the laptop works but everytime it wants me to type a supervisor password i never set.
                                            I thought the supervisor password is stuck in the ec bios but no it isn't either because after replacing the ec chip from one of another board it still has the supervisor password.
                                            Anyway i wanted to ask what of the two chips is the ec bios because on the left...
                                            04-17-2025, 03:42 PM
                                          • mferna14
                                            Password removal on MacBook Pro A2159
                                            by mferna14
                                            Hi friends., I am working on MacBook Pro A2159 touchbar 2019. The old logic board was liquid spilled so I ordered another logic board from AE. Received it & all worked fine till I got to the Chinese login screen where the login screen password tobe entered. I tried to reset the password but it again gave me options which I do not know about the Apple ID. I formatted the onboard SSD. & wanted to change the startup boot sequence but in order to change it, again the password is needed for that too. Is there a way to get rid of this password?? The seller has not replied back past 2 days, how...
                                            05-13-2025, 04:16 PM
                                          • Badpatch02
                                            Thinkpad X380 Yoga supervisor password removal + Intel ME removal question
                                            by Badpatch02
                                            Hi all, I'm new here, a few words about myself: CS student, interested in hardware stuff too - tinkering my whole life but with practically no experience when it comes to firmware "hacking".
                                            So I have this X380 Yoga with a supervisor password in place and before doing anything stupid I figured I'd rather ask.
                                            I plan on using the tool from this thread: https://www.badcaps.net/forum/troubl...password-remov...
                                            11-30-2024, 05:22 AM
                                          • Johnny h
                                            Asus M7600R BIOS Password request/removal
                                            by Johnny h
                                            I'm hoping someone can assist me.
                                            I have an Asus Vivobook 16x Pro OLED laptop which has a BIOS password, and I can't seem to find it.
                                            It still boots into Windows (boots from whatever SSD is installed but not from USB).
                                            The model number is M7600R and serial number is N8N0CX03H71131C.
                                            I tried AMITSESetup Decryptor but the password I got doesn't make sense (it's got a line break and special characters).
                                            I also tried to use *************** MOD EDIT ,redacted************** and it also gave me the funny password of
                                            Code:
                                            tmNx\'=QJQ
                                            04-10-2024, 06:13 AM
                                          • coolshrimp
                                            T14s - MEC-1663 - Jtag - Pinout - Bios Password Removal
                                            by coolshrimp
                                            Here is all the info you should need to remove bios password from your same model or one with an MEC-Chip and also write back the config data
                                            See Diagram for Wiring.
                                            Use MEC-1633#ISP on your RT809h
                                            This is same Jtag pinout and method for T490S/X390
                                            (But your R/W 10K Resistor Location May In a Different Location)
                                            MEC-Chips Store Bios Password In a Secure Un-Editable Area
                                            Following steps clear that secure area to re-initialize itself to default (Blank)
                                            10-24-2022, 12:18 AM
