hp 450 g7 password
  • satishkumar
    replied
    Re: hp 450 g7 password
    Originally posted by mesta83
    can anyone help me with unlocking this one please?
  • mesta83
    replied
    I tried, password still there
  • hardware1
    replied
    Can anyone help me with unlocking this one please?
    Try with RCunlocker.
    https://www.badcaps.net/forum/showpo...15&postcount=1
  • mesta83
    replied
  • hoaca388
    replied
    Originally posted by fredo
    Black screen
    Weird !
  • fredo
    replied
    Originally posted by hoaca388
    Here
    Black screen
  • hoaca388
    replied
    Originally posted by luisgarciaj
    remove password hp probook 450 g7 X8M-6L PLEASE
  • luisgarciaj
    replied
  • hoaca388
    replied
    Please help me to remove this error
    Here
  • fredo
    replied
  • ymifdal
    replied
    Try this one GL
    The main stays the same
  • alterr333
    replied
    Re: hp 450 g7
    Originally posted by Vesko356
    Try & leave feedback:
    Hello mate, please help me out with this HP 450 G7
    its bios was blocked, then i managed to get a working dump that i installed, but now the computer wont recognice the HDD
    would it be possible to unlock its original main and EC bios??
    attached main and EC bios
  • alterr333
    replied
    Originally posted by alterr333
    Done, had to put the file in the same folder then throw bin to the exe instead of openinx EXE prior
    Flashed back the BIN however pwd still set on bios
    cant login to return values default
    ideas are greatly appreciated,
    thank you so much in advance
  • alterr333
    replied
    Hey sir, what is that im doing wrong
    Received MISSING FILE DESTINATION ARGUMENT
    how could i fix this?
    thank you so much
  • alterr333
    replied
    Winbond's your bios chip. Unlock it with RC Unlocker.
    thank you so much
  • Fireballcz
    replied
    You are the man! Thank you for the 2nd time. You are BIOS boss!
  • hoaca388
    replied
    Originally posted by Fireballcz
    Hi Peste,
    Thanks, but no success. The prompt for pass remains the same. So clearing the part of starting with "NvramActiveRegn." (GD125B127D) was not helpful.
    So I flashed back original (locked) dumps. Laptop works untouched, as arrived - asking for password. This means, that reading/flashing (with reduced clk) IN PLACE must be 100% OK.
    Maybe Im missing something.
    Please see attached image and explain, if possible.
    There are two chips, both 128Mb (16MB)
    - GigaDevice GD25B127D (dump starts with a block of FF values)
    - Winbond W25Q128JV (dump starts with various values)
    Please:
    1) Which of them is the main one?
    2) Which of them should be altered by RCUnlocker?
    Many thanks for your time.
  • hoaca388
    replied
    Originally posted by NjoyDGM
    I did exactly the same thing but the password is still there. Can it somehow be recorded on the second EC flash?
    Maybe.
  • Fireballcz
    replied
    Originally posted by peste
    remove the bios chip from the motherboard before reading or writing it, don't use the clip because it gives errors..
    try..
    Hi Peste,
    Please:
  • Fireballcz
    replied
    remove the bios chip from the motherboard before reading or writing it, don't use the clip because it gives errors...
    Many thanks for your great work and info. Yes I have readed and also programmed both chips in place.
    May I ask a question?
    I have T56 and I lowered the clk speed to 5 MHz. The chip (both) powering resistance is bigger than 15 kOhms.
    I readed both chips TWICE and checked for differences (HEX, CRC). Both saved dumps for both chips were OK. No differences. Is it possible to read twice in place with IDENTICAL errors?
    If is this possible, it menas, that also the second chip Winbond W25Q128JV was readed improperly and need fix.
    May I ask also for fixing the second one - Winbond, in this case?
    Many thanks!
  • AppleLover123
    Lenovo Yoga X380 22LH Supervisor Password removal
    by AppleLover123
    Hey guys,
    have a laptop here that has a supervisor Password (dump in Attachements).
    Before i write the Serial NR.etc i wanted to say that strangely after flashing with 3 different Bios dumps and one from lenovos site
    the laptop works but everytime it wants me to type a supervisor password i never set.
    I thought the supervisor password is stuck in the ec bios but no it isn't either because after replacing the ec chip from one of another board it still has the supervisor password.
    Anyway i wanted to ask what of the two chips is the ec bios because on the left...
    04-17-2025, 03:42 PM
  • mferna14
    Password removal on MacBook Pro A2159
    by mferna14
    Hi friends., I am working on MacBook Pro A2159 touchbar 2019. The old logic board was liquid spilled so I ordered another logic board from AE. Received it & all worked fine till I got to the Chinese login screen where the login screen password tobe entered. I tried to reset the password but it again gave me options which I do not know about the Apple ID. I formatted the onboard SSD. & wanted to change the startup boot sequence but in order to change it, again the password is needed for that too. Is there a way to get rid of this password?? The seller has not replied back past 2 days, how...
    05-13-2025, 04:16 PM
  • Badpatch02
    Thinkpad X380 Yoga supervisor password removal + Intel ME removal question
    by Badpatch02
    Hi all, I'm new here, a few words about myself: CS student, interested in hardware stuff too - tinkering my whole life but with practically no experience when it comes to firmware "hacking".
    So I have this X380 Yoga with a supervisor password in place and before doing anything stupid I figured I'd rather ask.
    I plan on using the tool from this thread: https://www.badcaps.net/forum/troubl...password-remov...
    11-30-2024, 05:22 AM
  • Johnny h
    Asus M7600R BIOS Password request/removal
    by Johnny h
    I'm hoping someone can assist me.
    I have an Asus Vivobook 16x Pro OLED laptop which has a BIOS password, and I can't seem to find it.
    It still boots into Windows (boots from whatever SSD is installed but not from USB).
    The model number is M7600R and serial number is N8N0CX03H71131C.
    I tried AMITSESetup Decryptor but the password I got doesn't make sense (it's got a line break and special characters).
    I also tried to use *************** MOD EDIT ,redacted************** and it also gave me the funny password of
    Code:
    tmNx\'=QJQ
    04-10-2024, 06:13 AM
  • coolshrimp
    T14s - MEC-1663 - Jtag - Pinout - Bios Password Removal
    by coolshrimp
    Here is all the info you should need to remove bios password from your same model or one with an MEC-Chip and also write back the config data
    See Diagram for Wiring.
    Use MEC-1633#ISP on your RT809h
    This is same Jtag pinout and method for T490S/X390
    (But your R/W 10K Resistor Location May In a Different Location)
    MEC-Chips Store Bios Password In a Secure Un-Editable Area
    Following steps clear that secure area to re-initialize itself to default (Blank)
    10-24-2022, 12:18 AM
