hp 450 g7 password
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    #41
    Re: hp 450 g7
    Originally posted by mdasifbd
    Tried with that file ("450-G7-BackupBiosLocked-2021-09-12-03 NEW.zip").
    But the following errors showing.
    These errors are normal after unlocking, don't panic , log into bios, and reset security settings to default.
    Become a Badcaps supporter
    Thanks to all supporters.
    • mdasifbd
      • Aug 2021
      • 8
      • Bangladesh
      #42
      Re: hp 450 g7
      Originally posted by Vesko356
      This errors are normal after unlocking, don't panic , log into bios, and reset security settings to default.
      No, Power-On Authentication return back clicking on "Esc" button. It means restore the BIOS from back-up, most probably.
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        #43
        Re: hp 450 g7
        Both two files 450-G7-Locked-2021-09-11-01 NEW, and 450-G7-BackupBiosLocked-2021-09-12-03 NEW must be written to the corresponding chips simultaneously and then unlocking procedure will be OK. You're trying to flash only one chip at a time and then to test, but it won't work that way.
        • Genyi
          • Sep 2021
          • 10
          • Russia
          #44
          Re: hp 450 g7
          Hello!
          You can give DMMP BIOS (HP ProBook 450 G7 BIOS S71 dump).
          On the first and on the second BIOS.
          Thanks!
          • mdasifbd
            • Aug 2021
            • 8
            • Bangladesh
            #45
            Re: hp 450 g7
            You have done excellent job. Again many many thanks for your effort. Now there is no more "Power-On Authentication". Every function running perfectly.
            Both Main and Backup BIOS had been re-written as your instruction. I did one more thing, made a BIOS backup on pen-drive from HP's site. Also plug-in at the same time for extra caution.
            So HP Probook 450 G7 need to rewrite both BIOS to remove "Power-On Authentication".
            Appreciating your effort.
            Thank you Brother.
            Kind Regards
            Asif
            • chkintl93
              • Jun 2019
              • 47
              • usa
              #46
              Re: hp 450 g7
              Try & leave feedback:
              Can you help unlock the bios password of hp 450 g7?
              Thank you
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #47
                Re: hp 450 g7
                Thank you
                Upload bios dump from the second chip.
                • torrevieja
                  • Mar 2018
                  • 6
                  • Ukraine
                  #48
                  Re: hp 450 g7
                  Can you help unlock the Absolute Persistence of hp 450 g7?
                  • Bsolution
                    Banned
                    • Oct 2021
                    • 73
                    • punjab
                    #49
                    Re: hp 450 g7
                    Originally posted by torrevieja
                    hi,
                    can you help unlock the absolute persistence of hp 450 g7?
                    try
                    • torrevieja
                      • Mar 2018
                      • 6
                      • Ukraine
                      #50
                      Re: hp 450 g7
                      without success
                      • AmirJane
                        • Feb 2016
                        • 5
                        • Bosnia and Herzegovina
                        #51
                        Re: hp 450 g7
                        Thank you
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11193
                          • Viet Nam
                          #52
                          Re: hp 450 g7
                          Thank you
                          You can do it by yourself
                          https://www.badcaps.net/forum/showth...ht=rc+unlocker
                          • NjoyDGM
                            • Jun 2017
                            • 7
                            • Ukraine
                            #53
                            Re: hp 450 g7 password
                            Hello, can you pls help me with password? Don't know why but RCUnlocker doesn't work..
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11193
                              • Viet Nam
                              #54
                              Here
                              • Fireballcz
                                • Oct 2016
                                • 26
                                • Czech Republic
                                #55
                                Hello guys!
                                I was not succeed with RC unlocker. No video, spinning fan
                                May I also ask for pass removal or both chips unpassed dump?
                                Attached dumps of both chips GD and Winbond.
                                Thanks in advance!
                                • peste
                                  • Dec 2016
                                  • 12254
                                  • ROMANIA
                                  #56
                                  Originally posted by Fireballcz
                                  Hello guys!
                                  Thanks in advance!
                                  remove the bios chip from the motherboard before reading or writing it, don't use the clip because it gives errors..
                                  try..
                                  • NjoyDGM
                                    • Jun 2017
                                    • 7
                                    • Ukraine
                                    #57
                                    Originally posted by hoaca388
                                    Here
                                    I did exactly the same thing but the password is still there. Can it somehow be recorded on the second EC flash?
                                    • Fireballcz
                                      • Oct 2016
                                      • 26
                                      • Czech Republic
                                      #58
                                      Originally posted by peste
                                      remove the bios chip from the motherboard before reading or writing it, don't use the clip because it gives errors...
                                      Many thanks for your great work and info. Yes I have readed and also programmed both chips in place.
                                      May I ask a question?
                                      I have T56 and I lowered the clk speed to 5 MHz. The chip (both) powering resistance is bigger than 15 kOhms.
                                      I readed both chips TWICE and checked for differences (HEX, CRC). Both saved dumps for both chips were OK. No differences. Is it possible to read twice in place with IDENTICAL errors?
                                      If is this possible, it menas, that also the second chip Winbond W25Q128JV was readed improperly and need fix.
                                      May I ask also for fixing the second one - Winbond, in this case?
                                      Many thanks!
                                      • Fireballcz
                                        • Oct 2016
                                        • 26
                                        • Czech Republic
                                        #59
                                        try..
                                        Hi Peste,
                                        Thanks, but no success. The prompt for pass remains the same. So clearing the part of starting with "NvramActiveRegn." (GD125B127D) was not helpful.
                                        So I flashed back original (locked) dumps. Laptop works untouched, as arrived - asking for password. This means, that reading/flashing (with reduced clk) IN PLACE must be 100% OK.
                                        Maybe Im missing something.
                                        Please see attached image and explain, if possible.
                                        There are two chips, both 128Mb (16MB)
                                        - GigaDevice GD25B127D (dump starts with a block of FF values)
                                        - Winbond W25Q128JV (dump starts with various values)
                                        Please:
                                        1) Which of them is the main one?
                                        2) Which of them should be altered by RCUnlocker?
                                        Many thanks for your time.
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 11193
                                          • Viet Nam
                                          #60
                                          Maybe.
                                          • AppleLover123
                                            Lenovo Yoga X380 22LH Supervisor Password removal
                                            by AppleLover123
                                            Hey guys,
                                            have a laptop here that has a supervisor Password (dump in Attachements).
                                            Before i write the Serial NR.etc i wanted to say that strangely after flashing with 3 different Bios dumps and one from lenovos site
                                            the laptop works but everytime it wants me to type a supervisor password i never set.
                                            I thought the supervisor password is stuck in the ec bios but no it isn't either because after replacing the ec chip from one of another board it still has the supervisor password.
                                            Anyway i wanted to ask what of the two chips is the ec bios because on the left...
                                            04-17-2025, 03:42 PM
                                          • mferna14
                                            Password removal on MacBook Pro A2159
                                            by mferna14
                                            Hi friends., I am working on MacBook Pro A2159 touchbar 2019. The old logic board was liquid spilled so I ordered another logic board from AE. Received it & all worked fine till I got to the Chinese login screen where the login screen password tobe entered. I tried to reset the password but it again gave me options which I do not know about the Apple ID. I formatted the onboard SSD. & wanted to change the startup boot sequence but in order to change it, again the password is needed for that too. Is there a way to get rid of this password?? The seller has not replied back past 2 days, how...
                                            05-13-2025, 04:16 PM
                                          • Badpatch02
                                            Thinkpad X380 Yoga supervisor password removal + Intel ME removal question
                                            by Badpatch02
                                            Hi all, I'm new here, a few words about myself: CS student, interested in hardware stuff too - tinkering my whole life but with practically no experience when it comes to firmware "hacking".
                                            So I have this X380 Yoga with a supervisor password in place and before doing anything stupid I figured I'd rather ask.
                                            I plan on using the tool from this thread: https://www.badcaps.net/forum/troubl...password-remov...
                                            11-30-2024, 05:22 AM
                                          • Johnny h
                                            Asus M7600R BIOS Password request/removal
                                            by Johnny h
                                            I'm hoping someone can assist me.
                                            I have an Asus Vivobook 16x Pro OLED laptop which has a BIOS password, and I can't seem to find it.
                                            It still boots into Windows (boots from whatever SSD is installed but not from USB).
                                            The model number is M7600R and serial number is N8N0CX03H71131C.
                                            I tried AMITSESetup Decryptor but the password I got doesn't make sense (it's got a line break and special characters).
                                            I also tried to use *************** MOD EDIT ,redacted************** and it also gave me the funny password of
                                            Code:
                                            tmNx\'=QJQ
                                            04-10-2024, 06:13 AM
                                          • coolshrimp
                                            T14s - MEC-1663 - Jtag - Pinout - Bios Password Removal
                                            by coolshrimp
                                            Here is all the info you should need to remove bios password from your same model or one with an MEC-Chip and also write back the config data
                                            See Diagram for Wiring.
                                            Use MEC-1633#ISP on your RT809h
                                            This is same Jtag pinout and method for T490S/X390
                                            (But your R/W 10K Resistor Location May In a Different Location)
                                            MEC-Chips Store Bios Password In a Secure Un-Editable Area
                                            Following steps clear that secure area to re-initialize itself to default (Blank)
                                            10-24-2022, 12:18 AM
