please patch this ThinkPad S1 Yoga 12
lenovo yoga 12 bios locked help please
hello,
can you please help unlock my yoga 12 bios dump attached.
Thank youAttached Filesif you find these attachements useful please consider making a small donation to the site
I have a ZIPS3 LA A342P For Lenovo ThinkPad Yoga 12 Laptop with a locked bios, can somebody patch it?Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: please patch this ThinkPad S1 Yoga 12
read EC ,solution here
https://www.badcaps.net/forum/showpo...4&postcount=19Comment
First of all, thank you so much for figuring this out and sharing the solution!
I used your technique to read and clear the UEFI password of my Yoga 12.
Now for the remaining problem: Even though I can now enter the UEFI by just pressing enter (empty password), I cannot change any settings. I guess this is because the "lock UEFI BIOS settings" option is set to enable. Probably this prevents me from making any changes.
Any thought on how this can be resolved?
EDIT: Nevermind. I repeated all steps from scratch and now it works
News
Patch possible on yoga 12
Pach by bios, no need to reprogram EC (Kb9022Q)
- Just read the two bios files (8+4MB)
and join them with utility provided.
Use Uefi Tools to modify your BIOS
Extract as is LenovoPasswordCP E4F272DA-237F-454C-8868-FCF096CF1C6C
Search AA382865-12B0-44E5-A731-6DEF4DF34CE7 LenovoPromptService
Replace as is LenovoPromptService by LenovoPasswordCP
LenovoPasswordCP must appear twice after
Split your file, select 8 for first file
Cleaning can help but not necessary
Password CP and Prompt may appear several times in relation to the bios templates, so all of them will need to be replaced
The patch allows you to access setup
- Load by default for the first time and restart
- Enter setup and go security
- type a blank password twice and save.
- Turn off, restore your original bios.
If you don't restore, the password will never be asked again!!
Tested here : https://youtu.be/f43JuDzA3yU
Booting may take time with different melodies, be patient!!
This patch also works on other models
https://www.badcaps.net/forum/troubl...10#post1873410
I'll leave you tested,
No Prompt, No Password
For clear EC KB9022Q as previously cited
Just replace 0x200 to 022F on your original EC Dump
no lost UUID ,serial and others numbers
Can someone help me create a patcher with python
because the autopatcher does not extract, just replaces.
I don't understand anything about python
I tried this but for some reason I cannot get the laptop to boot with the modified image
What am I doing wrong, Is there a trick to getting it to boot with the modified BIOS?
I tried also the auto patcher linked here https://www.badcaps.net/forum/troubl...age169?t=87588
but could not get it to boot.
I attached the original BIOS file reads, read and flashed with a CH341A.
try only 64,32 it's sameI tried this but for some reason I cannot get the laptop to boot with the modified image
I attached the original BIOS file reads, read and flashed with a CH341A.Attached Filesif you find these attachements useful please consider making a small donation to the site
I flashed the 8 MB W25Q64FV chip with the file "64 try test.bin" but still was not able to get a boot after trying for a while. The CPU fan spins for 3-5 seconds before stopping, CPU gets warm no video on display.
I also tried with and without the CMOS battery and also pressing the button on the motherboard.
I have only the display, charger and power button&sata board connected not sure if that matters but it would boot previously like this.
I had noticed the 4 MB part of the image was the same for the stock and modified so I only verified the dump matches before reinstalling. (I also verified the 8 MB chip after flashing)
Maybe I am doing something wrong in programming? Not sure.Comment
If you put the original back, does it work again? So the programming is good
This is very strange, I programmed the original BIOS back to the 8M chip and the board still does not boot, I even tried swapping the flash chips off a similar dead board (shorted PCH) and still got no boot.
I verified with an older board the LCD is still working also.
I have been comparing this board to the dead one to see if I knocked off a component but I don't see any knocked off. There are some resistors in different positions but I believe those are the straps for the ram as the dead board only had 4GB of ram if I recall and the locked one has 8GB.
Any idea what might have happened?
Maybe I somehow killed the SIO? I'm assuming the power rails are all present since the CPU has power right? I would think that would be last in the sequence.
I also wonder about the ram solder balls but I would think I would get a beep code if one of the ram chips became disconnected.
I must have screwed something up but I have know idea what I did
Hello eveyone, I would like to know if someone here still have the lenovo yoga 12 working. I would like to ask for some features about bios version and chipset version because i am facing a problem with a lenovo yoga 12, it only shows video by a external monitor but no video on display. I have a new lcd flex, new screen, no backlight problem. Everythings looks ok but somehow doesnt detect the lcd.Comment
if it displays on the external monitor, it's not a bios problem... check the LVDS cable, display, connectors, video chipset... move the discussion to the main forum...Hello eveyone, I would like to know if someone here still have the lenovo yoga 12 working. I would like to ask for some features about bios version and chipset version because i am facing a problem with a lenovo yoga 12, it only shows video by a external monitor but no video on display. I have a new lcd flex, new screen, no backlight problem. Everythings looks ok but somehow doesnt detect the lcd.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
The issue is that I got a display on the LCD with an Ubuntu Live USB, but only until the system finished booting. All previous system messages were ignored by the LCD (but appeared on the external monitor). So I decided to reflash the BIOS. After that, I only had the external monitor working. Things got weird from there because even after reflashing the original BIOS, I couldn't get the Live USB video output back.Comment
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
This specification for the Lenovo ThinkPad ThinkPad X1 Titanium Yoga Gen 1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad X1 Titanium Yoga Gen 1 boardview and ThinkPad X1 Titanium Yoga Gen 1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...09-07-2024, 04:10 AM
by Loki_FidoHi everyone, hope everyone's having a great day.
I have a Lenovo Thinkpad X1 Yoga Gen 3 for repair. (20LES3T900)
I looked in every corner and the laptop seems fine. Its pulling 500mA but no display, no noise, nothing.
So I assume its a BIOS issue. I downloaded the BIOS with CH341A and opened it on ME Analyser and didn't receive any errors.
Does this mean the BIOS is fine? making it a hardware issue?
I downloaded fresh BIIOS from the Lenovo site and used Hex Editor replace the Lenovo's BIOS into my BIOS region. But the file size ended up being...-
This specification for the Lenovo ThinkPad ThinkPad X13 Yoga Gen 2 (Intel) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad X13 Yoga Gen 2 (Intel) boardview and ThinkPad X13 Yoga Gen 2 (Intel) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...09-07-2024, 05:00 AM
- Loading...
