Asus tp200sa e205sa rev 2.0
  • bilen
    • Aug 2014
    • 638
    • istanbul
    motherboard code : e205sa rev 2.0 need clean me bios dump
    old bios not screen:
  • peste
    • Dec 2016
    • 12933
    • ROMANIA
    Re: Asus tp200sa
    try..
    • bilen
      • Aug 2014
      • 638
      • istanbul
      Re: Asus tp200sa
      Originally posted by peste
      try..
      not working. power on and restart. no screen.
      • peste
        • Dec 2016
        • 12933
        • ROMANIA
        Re: Asus tp200sa
        try..
        • bilen
          • Aug 2014
          • 638
          • istanbul
          Re: Asus tp200sa
          try..
          thank you. problem not solved. returned to customer
            • 21142
            Re: Asus tp200sa
            bios
            • kalilinux25
              • Mar 2018
              • 2089
              • ZAMBOANGA SIBUGAY
              Asus clean and latest update for E205SA REV 2.0
              MB: E205SA REV 2.0
              CODE: 60NL0080-MB3500-202
              LAPTOP TP200S-FV0128D
              SN: FBNLCX16018946C
              power but no display
              • peste
                • Dec 2016
                • 12933
                • ROMANIA
                Re: Asus clean and latest update for E205SA REV 2.0
                Originally posted by kalilinux25
                MB: E205SA REV 2.0
                SN: FBNLCX16018946C
                try..
                • kalilinux25
                  • Mar 2018
                  • 2089
                  • ZAMBOANGA SIBUGAY
                  try..
                  Thanks sir fully working so nice
                  • felix38
                    • Apr 2022
                    • 7
                    • türkiye
                    Re: Asus tp200sa
                    try..
                    it is worked thank you friend
                    • razor_amd
                      by razor_amd
                      12-15-2020, 07:07 PM
                    • Technodoc
                      ASUS G614JZ-N3012W Rog Strix need some bios help, laptop black screen
                      by Technodoc
                      Asus laptop G614JZ-N3012W Rog Strix with i7
                      Mainboard G634J-PMV-VGT
                      6050A3441302-MB-A01
                      2023-02-10
                      Power button works okay....power light goes on
                      Red "bottom" leds go on
                      Charging led works
                      Fans do not spin, capslock key does nothing, screen stays black
                      I would like to program the bios again, to rule out a corrupted bios.
                      However I run into a size error
                      The bios chip is a Winbond 25R256JVEN
                      Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
                      02-24-2025, 04:46 AM
                    • DynaxSC
                      by DynaxSC
                      06-14-2024, 03:49 PM
                    • Ahari
                      by Ahari
                      I...
                      08-13-2025, 06:12 AM
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
