Dell E6230 A20 BIOS dump needed!
  • emre22232
    • Dec 2020
    • 19
    • Austria
    Hi! As the title explains, a Dell E6230 I have at home is not booting. I wanted to fix it, as it's holiday right now and I don't have something to do in this time.
    The problem is:
    This laptop won't boot unless I remove the CMOS battery and wait for 5 minutes. Then, it boots up normally with a warning ("Date and Time not set, that's normal.."). As soon as it's starting, it works normally without any problems. I flashed the BIOS using a dump here on Badcaps, as the BIOS was corrupt, too. When I try to update the BIOS from Windows/DOS, it prepares the update, then just restarts and boots straight into Windows without even trying to install the BIOS update.. something wrong with the ME region of the BIOS? Or am I wrong?
    I'd be thankful if someone would try to help.
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: Dell E6230 i5 not booting.
    Date and time not set warning
    Cause is CMOS cell dead
    Replace CMOS battery with new one and all problem will resolve
    Bios was not corrupted until you flash it
    Now change CMOS battery and check normal
    No need to update bios
    • emre22232
      • Dec 2020
      • 19
      • Austria
      I ordered new batteries. The problem is that the laptop was not booting at all till I flashed the BIOS with a CH341A programmer. It worked then, but reinserting the CMOS cell made it not booting again. I want the A20 BIOS, as I think the older A12 BIOS (which is right now installed on the BIOS chip) has a lot of bugs.
      Thanks.
        • 20286
        Thanks.
        You`ve already asked in another thread for the A20 bios -
        https://www.badcaps.net/forum/showth...ighlight=E6230
        • emre22232
          • Dec 2020
          • 19
          • Austria
          Ups, sorry for spamming. Will not do that again.
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • mikeybass
            by mikeybass
            04-23-2025, 04:30 PM
          • jamaica12345
            dell vostro 3710 bios dump needed
            by jamaica12345
            i need dump bios dell vostro 3710 please help
            Service Tag 2FL5NY3
            CI bios
            MX25L25635
            MX25L12805...
            09-29-2024, 12:34 PM
          • vinaypundith
            Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
            by vinaypundith
            I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
            So, I'm looking for a BIOS dump for this machine - a 16MB one....
            08-03-2024, 12:32 PM
          • James Maxwell
            HP DM1-4000er Bios Dump needed
            by James Maxwell
            I badly need bios dump for HP DM1-4000er,
            Model: HP DM1-4000er
            Motherboard: DA0NM9MB6D0 REV.D
            Product: QJ490EA#ACB
            Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
            10-28-2024, 05:38 PM
