Hi good day to all those anone has a working bios I have a core i5 and amd gpu backup is attached, hope someone can help me.I tried somebios on the forum but nothings works it wont poweron the unit,
Dell Vegas/Turis SKL7KBL 15341-191N85
Tags: None
Re: Dell Vegas/Turis SKL7KBL 15341-191N85
try..Attached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs. -
i tried the bios pressing powert the board will power but no display fans spins dramatically then after that you cant power on the unit again , you need to remove the charger and power it again. Did I just killed the board when trying different types of bios?Comment
flash ec and main both bios and check if laptop back to lifeAttached Filesif you find these attachements useful please consider making a small donation to the site
mr.peste has given file is configured and healthy
try to flash given both bios if not response than replace your bios chip and still it has same issue than start probing in and and check its hardware requirementsComment
Thanks I'll just need to order the bios chip first, is my IO CHIP ok?Comment
so we dont know where did it exactly stuck during update it could be a kbc or could be a main bios
in that case i will recommend you to flash both bios at a time
hopefully it will resolve the issue
above i have given you tested kbc+main bios you may try
for further help we are there for youComment
im very thankful sir . Ill update if the bios chip arriveso we dont know where did it exactly stuck during update it could be a kbc or could be a main bios
I have a dso sir just arrive yesterday how can I identify if its a bios or kbc problem sir?so we dont know where did it exactly stuck during update it could be a kbc or could be a main bios
i cant explain the whole bios process
i can just explain it in 1 sentence. BIOS to be work the logic signal should be HIGH-LOW 3 times than it will LATCH & start work
by RofixHi everyone, I wanted to kindly ask you for help, I have a problem with my Dell vegas/turis mlk kbl-r 17841-1 wx2rr PC, it turned off and I was no longer able to turn it back on, I'm checking the various voltages, unfortunately I found the 19 v up to the input components PU4411, PQ4401, thank you all for any advice
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by IamPriteshI have two such machines which is having this issue. After shutdown the system starts on its own in a minute. It does not start immediately. It takes around 20-40 seconds before it starts again on its own. This is driving me crazy and not sure where to start ..
Some very important points :
- Laptop does not auto starts after shutdown if adapter is connected.
- It will only auto start after shutdown if the laptop is in BATTERY only mode.
- I have tried replacing batteries with a known
- if I shutdown the laptop with adapter connected and lets say remove the adapter after 5-10
by JmineHello guys,
I've got this motherboard with me that turns on when the charger is connected(without pressing the power button), the fan is fully spinning and it doesn't display anything. there is led flashing 3 amber 5 white. voltage readings are also weird, sorry I couldn't find the schematics for the board.
Voltages are as follows,
@ PL5301: 1.015V
@ PL4401: NO voltage
@ PL4501: 5.100V
@ PL4502: 3.408V
@ PL5101 near RTC: NO voltage
@ PL5001, PL4801 PL4802, PL4701: NO Voltages
Looking forward for your guidance... -
Hi everybody,
I have a Dell Vostro laptop with the VEGAS/TURIS SKL/KBL 15341-1 motherboard. Without notice, the other day the laptop was dead and as soon as I plug the charger in, the LED on the charger itself shuts off, as if detecting a short circuit in the motherboard. Measuring on the board between + and - of the plug shows no evident shorts (readings are in the hundreds of kOhms). If I plug a bigger charger with a higher current limit, it will stay on and some chips get hot. Using a thermal IR camera, a couple of mosfets get hot (but, testing them, they are not shorted, I think they... - Loading...
