Dell Vegas/Turis SKL7KBL 15341-191N85
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi good day to all those anone has a working bios I have a core i5 and amd gpu backup is attached, hope someone can help me.I tried somebios on the forum but nothings works it wont poweron the unit,
  • peste
    • 12902
    • ROMANIA
    Re: Dell Vegas/Turis SKL7KBL 15341-191N85
    try..
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      Originally posted by peste
      try..
      i tried the bios pressing powert the board will power but no display fans spins dramatically then after that you cant power on the unit again , you need to remove the charger and power it again. Did I just killed the board when trying different types of bios?
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        try..
        I tried flashing the original bin it ownt power at all
        • qayyum786
          • Aug 2018
          • 1933
          • INDIA
          i tried flashing the original bin it ownt power at all
          flash ec and main both bios and check if laptop back to life
          • kalilinux25
            • Mar 2018
            • 2089
            • ZAMBOANGA SIBUGAY
            how to flash the ec ? the lapto wont power sir?
            • qayyum786
              • Aug 2018
              • 1933
              • INDIA
              if you dont have programmer for EC try to flash main bios only first
              • kalilinux25
                • Mar 2018
                • 2089
                • ZAMBOANGA SIBUGAY
                I tried now the laptop will pwoer but no display fan spins fast
                • kalilinux25
                  • Mar 2018
                  • 2089
                  • ZAMBOANGA SIBUGAY
                  I only have a sasjig 3.8 io programmer and theboard has a JTAG MEC ic, i dont have a board view I cant I dentify where to jumper the jtag wires
                  • qayyum786
                    • Aug 2018
                    • 1933
                    • INDIA
                    as i said to you try first given 16 MB main bios &check if your laptop response
                    • kalilinux25
                      • Mar 2018
                      • 2089
                      • ZAMBOANGA SIBUGAY
                      as said try first try 16 MB main bios first check if your laptop response
                      Laptop wont display not like the other bios ive tried it wont turn on but your bios is trying to display the unit but it wont display.
                      • kalilinux25
                        • Mar 2018
                        • 2089
                        • ZAMBOANGA SIBUGAY
                        update sir after testing unit wont power on again
                        • qayyum786
                          • Aug 2018
                          • 1933
                          • INDIA
                          mr.peste has given file is configured and healthy
                          try to flash given both bios if not response than replace your bios chip and still it has same issue than start probing in and and check its hardware requirements
                          • kalilinux25
                            • Mar 2018
                            • 2089
                            • ZAMBOANGA SIBUGAY
                            Thanks I'll just need to order the bios chip first, is my IO CHIP ok?
                            • qayyum786
                              • Aug 2018
                              • 1933
                              • INDIA
                              what was your actual problem ?
                              • kalilinux25
                                • Mar 2018
                                • 2089
                                • ZAMBOANGA SIBUGAY
                                Its was firmware update bios failed sir stockup on dell bios then I treid emmidiatly to flashed it
                                • qayyum786
                                  • Aug 2018
                                  • 1933
                                  • INDIA
                                  so we dont know where did it exactly stuck during update it could be a kbc or could be a main bios
                                  in that case i will recommend you to flash both bios at a time
                                  hopefully it will resolve the issue
                                  above i have given you tested kbc+main bios you may try
                                  for further help we are there for you
                                  • kalilinux25
                                    • Mar 2018
                                    • 2089
                                    • ZAMBOANGA SIBUGAY
                                    im very thankful sir . Ill update if the bios chip arrive
                                    • kalilinux25
                                      • Mar 2018
                                      • 2089
                                      • ZAMBOANGA SIBUGAY
                                      I have a dso sir just arrive yesterday how can I identify if its a bios or kbc problem sir?
                                      • qayyum786
                                        • Aug 2018
                                        • 1933
                                        • INDIA
                                        i cant explain the whole bios process
                                        i can just explain it in 1 sentence. BIOS to be work the logic signal should be HIGH-LOW 3 times than it will LATCH & start work
                                        • Rofix
                                          Problem Dell vegas/turis mlk kbl-r 17841-1 wx2rr
                                          by Rofix
                                          Hi everyone, I wanted to kindly ask you for help, I have a problem with my Dell vegas/turis mlk kbl-r 17841-1 wx2rr PC, it turned off and I was no longer able to turn it back on, I'm checking the various voltages, unfortunately I found the 19 v up to the input components PU4411, PQ4401, thank you all for any advice
                                          04-24-2024, 03:48 AM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • IamPritesh
                                          Help - Auto starts after 1 minute of shutdown - Dell vegas/turis 15341-1
                                          by IamPritesh
                                          I have two such machines which is having this issue. After shutdown the system starts on its own in a minute. It does not start immediately. It takes around 20-40 seconds before it starts again on its own. This is driving me crazy and not sure where to start ..
                                          Some very important points :
                                          • Laptop does not auto starts after shutdown if adapter is connected.
                                          • It will only auto start after shutdown if the laptop is in BATTERY only mode.
                                          • I have tried replacing batteries with a known
                                          • if I shutdown the laptop with adapter connected and lets say remove the adapter after 5-10
                                          09-24-2021, 05:01 AM
                                        • Retrocomputer
                                          Dell Vostro 15 VEGAS/TURIS SKL/KBL 15341-1 short circuit
                                          by Retrocomputer
                                          Hi everybody,
                                          I have a Dell Vostro laptop with the VEGAS/TURIS SKL/KBL 15341-1 motherboard. Without notice, the other day the laptop was dead and as soon as I plug the charger in, the LED on the charger itself shuts off, as if detecting a short circuit in the motherboard. Measuring on the board between + and - of the plug shows no evident shorts (readings are in the hundreds of kOhms). If I plug a bigger charger with a higher current limit, it will stay on and some chips get hot. Using a thermal IR camera, a couple of mosfets get hot (but, testing them, they are not shorted, I think they...
                                          07-16-2021, 03:40 AM
                                        • Jmine
                                          Dell Vegas/Turis MLK KBL-R 17841-1 WX2RR
                                          by Jmine
                                          Hello guys,
                                          I've got this motherboard with me that turns on when the charger is connected(without pressing the power button), the fan is fully spinning and it doesn't display anything. there is led flashing 3 amber 5 white. voltage readings are also weird, sorry I couldn't find the schematics for the board.
                                          Voltages are as follows,
                                          @ PL5301: 1.015V
                                          @ PL4401: NO voltage
                                          @ PL4501: 5.100V
                                          @ PL4502: 3.408V
                                          @ PL5101 near RTC: NO voltage
                                          @ PL5001, PL4801 PL4802, PL4701: NO Voltages
                                          Looking forward for your guidance...
                                          02-20-2023, 03:13 AM
