Dell Vegas/Turis SKL7KBL 15341-191N85
  • apodaca
    Apodaca
    • 11
    • Mexico
    Originally posted by peste
    Re: Dell Vegas/Turis SKL7KBL 15341-191N85
    try..
    Work fibe for me thanks!!!!
    • Rofix
      Problem Dell vegas/turis mlk kbl-r 17841-1 wx2rr
      by Rofix
      Hi everyone, I wanted to kindly ask you for help, I have a problem with my Dell vegas/turis mlk kbl-r 17841-1 wx2rr PC, it turned off and I was no longer able to turn it back on, I'm checking the various voltages, unfortunately I found the 19 v up to the input components PU4411, PQ4401, thank you all for any advice
      04-24-2024, 03:48 AM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • IamPritesh
      Help - Auto starts after 1 minute of shutdown - Dell vegas/turis 15341-1
      by IamPritesh
      I have two such machines which is having this issue. After shutdown the system starts on its own in a minute. It does not start immediately. It takes around 20-40 seconds before it starts again on its own. This is driving me crazy and not sure where to start ..
      Some very important points :
      • Laptop does not auto starts after shutdown if adapter is connected.
      • It will only auto start after shutdown if the laptop is in BATTERY only mode.
      • I have tried replacing batteries with a known
      • if I shutdown the laptop with adapter connected and lets say remove the adapter after 5-10
      09-24-2021, 05:01 AM
    • Jmine
      Dell Vegas/Turis MLK KBL-R 17841-1 WX2RR
      by Jmine
      Hello guys,
      I've got this motherboard with me that turns on when the charger is connected(without pressing the power button), the fan is fully spinning and it doesn't display anything. there is led flashing 3 amber 5 white. voltage readings are also weird, sorry I couldn't find the schematics for the board.
      Voltages are as follows,
      @ PL5301: 1.015V
      @ PL4401: NO voltage
      @ PL4501: 5.100V
      @ PL4502: 3.408V
      @ PL5101 near RTC: NO voltage
      @ PL5001, PL4801 PL4802, PL4701: NO Voltages
      Looking forward for your guidance...
      02-20-2023, 03:13 AM
    • Retrocomputer
      Dell Vostro 15 VEGAS/TURIS SKL/KBL 15341-1 short circuit
      by Retrocomputer
      Hi everybody,
      I have a Dell Vostro laptop with the VEGAS/TURIS SKL/KBL 15341-1 motherboard. Without notice, the other day the laptop was dead and as soon as I plug the charger in, the LED on the charger itself shuts off, as if detecting a short circuit in the motherboard. Measuring on the board between + and - of the plug shows no evident shorts (readings are in the hundreds of kOhms). If I plug a bigger charger with a higher current limit, it will stay on and some chips get hot. Using a thermal IR camera, a couple of mosfets get hot (but, testing them, they are not shorted, I think they...
      07-16-2021, 03:40 AM
