x556uj dont turn off
  • Anethra
    • Dec 2018
    • 70
    • Turkey
    when i shutdown from system, all devices turn off but fan keep going to work. and power light up. im thinking about me region. org me in bios 11.0.0.1180 , i tryed with 1183 and 1178 but these me region cant take image from notebook. org. bios in attachment
  • peste
    • 13924
    • ROMANIA
    Re: x556uj dont turn off
    try..
    • Anethra
      • Dec 2018
      • 70
      • Turkey
      Originally posted by peste
      try..
      same problem
      • qayyum786
        • Aug 2018
        • 1959
        • INDIA
        same problem
        FLASH YOUR ORIGINAL DUMP
        STAR YOUR LAPTOP
        DOWANLOAD ME IN .EXE FOAM FROM GIVEN LINK BELOVE AND CHK IF IT RESOLVE THE ISSUE
        https://dlcdnets.asus.com/pub/ASUS/n...ER11001162.zip
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          This is not bios related at all. I see two probabilities
          01.lan chip is bad
          02.3V/5V DC to DC Load switch is faulty. eg EM5106VT
          The IC may not be same in your board but you need to check enable pin on this load switch. The EN pin should drop to 0 when turned off but perhaps its not going down to 0.
          Not every problem is bios related friends.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            No update??Was your problem solved with above steps or you didnt tried??
            • pajdek
              Lenovo Y700-17ISK turn on and off
              by pajdek
              Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
              09-20-2023, 02:49 AM
              ASUS X556UJ-XO046T Notebook Specification for Upgrade or Repair
              This specification for the ASUS X556UJ-XO046T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X556UJ-XO046T boardview and X556UJ-XO046T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
              09-06-2024, 08:27 AM
            • RdeveLabs
              MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
              by RdeveLabs
              To all the members here...
              Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
              So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
              05-05-2025, 04:59 AM
            • reessi
              Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
              by reessi
              Hello:
              I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
              I started on the ACER:
              Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
              All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
              I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
              10-29-2024, 11:31 AM
            • robante15
              Acer Aspire 4520 won't turn on after reboot
              by robante15
              Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
              It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
              The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
              If I remove the...
              04-06-2024, 06:50 PM
