gs44d/gs54d nm-c711 rev1.0 HELLPPPP!
Last edited by volinakis; 06-30-2024, 04:36 AM.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Need help, unit blinking led .
S/N PF1SY63L
MODEL: 81W6
Original bios attached.Attached FilesComment
https://www.badcaps.net/donateComment
hii all i programmed bios on my laptop and not getting boot ROM based configuration msg show that any help please
RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
hi could you help me with this bios gs44d/gs54d nm-c711 rev1.0 (2019-09-18) thanksComment
Hi i have a gs44d/gs53d nm-c711 serial: PF1T48Q6 and I need help unlocking this bios. ThanksAttached FilesComment
Can someone disable the integrated ram on the motherboard in the bios Lenovo V15-IIL Model 82c5 SN: PF299125 gs44d/gs54d nm-c711 rev1.0
I have tried MAIN_NO_OB_RAM and it takes me more than 1 minute to display the image.Attached FilesComment
Every donation made will go towards server fees and maintenance costs.Comment
you have everything you need at post #33...
https://www.badcaps.net/forum/troubl...s-please/page2Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Hello, can you help me with this bios Lenovo V15IIL Model 82C5,PF35WEF6 MTM 82C500R0YA,,GS44d/GS54d NM-C711 rev1.0 (2019-09-18), when I start it, the fan spins turns off, the LED indication stays on for 20 seconds, then everything repeats endlessly, thanksAttached FilesComment
Attached Files↵
by BlackHhello friends..
DC Jack is ok.. 20V entering the first MOSFET,, but nothing out..
using my power jack to inject 20V after the first MOSFET, nothing out.
but after inject 20V after the second FOSFET, the board worked,,
when i remove the first MOSFET,, and inject 20V at the input of second MOSFET, the board worked,,
try to change the first MOSFET,, but nothing changed.
so i try to jumber the first MOSFET,, all things worked .. but the board can't charge the battery.
i test the battery,, and its working very good..
any suggestions?... -
Hello I Need to Clear this Bios Password
LENOVO V15 IIL GS44D GS54D NM-C711
I Write another to password cleared But Hdd Not detected
So Pls Need to Clear this bios Password...-
Channel: BIOS Requests ONLY!
by dr.thodtFor the second time this week I received a Lenovo laptop with onboard ram and one sodimm slot. Both laptops run stable from their onboard 4GB RAM, but turn out to be very unstable when there's a sodimm inserted in the slot.
Both times it was a GS44D/GS54D NM-C711 rev 1.0 board.
Both times there were no loose pins on the slot and it did not matter what sodimm I put in. It just artefacts and crashes randomly when there's extra ram.
What I did notice is that almost all coils have very dirty phases one the mosfet side when checked with an oscilloscope. Not something I see very often....06-07-2024, 09:16 AM -
by DrFalkenHello guys,
Lenovo V15-IIL M/B GS44D/GS54D NM-C71 Rev 1.0
Customer say that this laptop died righe after connecting an cheap aftermarket PSU.
Some readings:
- VIN = 20V
- PQ100 pin1-3 = 0
- PQ100 pin4 = 0
- PQ100 pin5 = 20V
- V9B+ [PR100 pin4] = 0
- +3VALW [RI4509 pin2] = 0
- +5VALW [UI4302 pin5] = 0
- +3VALW_PCH [DC701 pin2] = 0
- +1.8VALW [RX4601 pin1] = 0
- +VCCIN_AUX [PL9801 pin2] = 0
- ACDRV [PR105 pin2] = 0
- REGN [PC118 pin1] = 6,65V -
by ArminioHi all, I'm new to the forum and need some help....
I have a notebook with a gs44d/gs54d nm-c711 motherboard which, after a few days of turning on and off by itself, never turned on again. there seems to be no power.
thank you - Loading...
