Lenovo (GS44D/GS54D NM-C711 Rev:1.0) Motherboard not working
  • BlackH
    • May 2022
    • 8
    • Palestine
    hello friends..
    DC Jack is ok.. 20V entering the first MOSFET,, but nothing out..
    using my power jack to inject 20V after the first MOSFET, nothing out.
    but after inject 20V after the second FOSFET, the board worked,,
    when i remove the first MOSFET,, and inject 20V at the input of second MOSFET, the board worked,,
    try to change the first MOSFET,, but nothing changed.
    so i try to jumber the first MOSFET,, all things worked .. but the board can't charge the battery.
    i test the battery,, and its working very good..
    any suggestions?
    thank you
  • FriedFred
    • May 2024
    • 137
    What is the GATE voltage at those MOSFETs? Needs to be about 25V or so.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Jumpering a dc-in mosfet will always disable charging and may show short circuit when both adapter+battery is plugged in together. So not advised to do so.
      The mosfet is disabled for reason.
      Measure resistance between
      01. Source-Drain
      02.Source to Gate
      03.Gate to drain
      of 2 dc0in mosfets with no power attached. meter should be in atleast 200K or higher scale.
      Which charging IC is used?
      • Jane
        How do you test MOSFET in laptops ?
        by Jane
        I tried to use this method:
        Testing an N-channel MOSFET:
        Step 1: Discharge the Gate (turn off the MOSFET)
        Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
        Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
        Step 2: Charge the Gate (turn on the MOSFET)
        Now, place the red probe on the Gate (G) and the black probe on the
        09-27-2024, 03:31 AM
      • Nooy
        VGA MOSfet permanently shorted and loss of MOSfet pad
        by Nooy
        Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
        I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
        02-14-2024, 02:26 AM
      • AppleLover123
        Asus X712EA 3 volts after the first mosfet
        by AppleLover123
        Hey guys,
        i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
        I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
        Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
        I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
        Now i thought something...
        12-15-2024, 07:49 AM
      • MicroSMD Lab
        by MicroSMD Lab
        I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
        01-10-2024, 06:36 AM
      • Scotchmist
        Asus GA502D keeps blowing mosfet
        by Scotchmist
        I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
        I have removed the mosfet and can run the laptop no problem
        The MOSFET is FDPC5018SG
        Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
        08-24-2024, 02:23 PM
