Hi, need help, can someone send me bios bin file for Samsung NP-NC215S.The laptop boot but having no display on both internal & external screen. Dump submitted.
Samsung NP-NC215S Bios
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
Channel: BIOS Requests ONLY!
by q2v5Lenovo T480s
Model 20L8-S3TE00
Board ET481-U10
Chip MX25L12873F
Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...-
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by eltano4i201) Error trying to enter the BIOS
--> [F2] won't let me enter the BIOS. To enter the BIOS, I had to create a shortcut and then type C:\Windows\System32\shutdown.exe /r /fw /t 1 in the destination. This forced it to restart and enter the BIOS.
Once inside, I went to the BOOT menu, but, surprise, it wasn't there. I got the following message:
BOOT PRIORITY ORDER (img-05)
1- Windows Boot Manager
2- SATA HDD
3- NETWORK
4- Debian
2) Error trying to access the BOOT MENU
--> I restarted the notebook and pressed [F10] but the BOOT... -
by NeddsmeHie.
I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
I managed to run Windows troubleshooting and...-
- Loading...
