Need bios Asus K56CB-XO488H
  • Gripen
    • Sep 2020
    • 37
    • Slovakia
    Hello. I have Asus K56CB-XO488H laptop. It was bad, but it was fixed. The BIOS chip was also missing, so I put a new one on it, but I don't have the original BIOS.
    I tried this bios dump.(#3) The laptop works perfectly except for one problem. A few seconds after laptop power on, when the fan starts, it runs always at maximum speed.
    I'm still a beginner in BIOS/BIOS flash, but I read that this is a bios problem. How can this be solved?
  • peste
    • 12499
    • ROMANIA
    Re: Need bios Asus K56CB-XO488H
    try..
    • Gripen
      • Sep 2020
      • 37
      • Slovakia
      Originally posted by peste
      try..
      I saw it. My laptop is an intel i5 but I tried it and it does the same. The fan always runs at 100% a few seconds after power on.
      • Gripen
        • Sep 2020
        • 37
        • Slovakia
        I found the original bios chip that was on it. This will not start. I read the chip but can't open it with UEFITool. Can this be fixed somehow?
        • peste
          • 12499
          • ROMANIA
          the bios is not ok ... please read it again and post ..
          • Gripen
            • Sep 2020
            • 37
            • Slovakia
            This is the problem. Always read this.
            I tried bios what you sent, it works with my laptop, but the fan always goes 100%.
            • peste
              • 12499
              • ROMANIA
              maybe you have another problem on the board ... check with another fan ...
              • Gripen
                • Sep 2020
                • 37
                • Slovakia
                I don't have such a fan at home, only HP. I'll look at work tomorrow.
                I would have another question, if the HP laptop(Zbook 15, 650 G2, etc ..) says "Machine is not in committed state" is how to fix it? I entered the data (serial, product id, etc ...) with DMItool.
                • peste
                  • 12499
                  • ROMANIA
                  try to clean ME region, if it still doesn't work, look for a bios in the bios requests section, if you can't find it, post the full name and model of the laptop, the model of the motherboard and the original
                  • Gripen
                    • Sep 2020
                    • 37
                    • Slovakia
                    I will try, thank you. I only ask because I am interested and want to learn these. I have a couple of laptops at work that write this error.
                    • qayyum786
                      • Aug 2018
                      • 1933
                      • INDIA
                      Try
                      • Gripen
                        • Sep 2020
                        • 37
                        • Slovakia
                        Originally posted by qayyum786
                        It does the same.
                        • qayyum786
                          • Aug 2018
                          • 1933
                          • INDIA
                          Originally posted by gripen
                          it does the same.
                          ok then peste is right
                          you just try with unplug the fan from connector and give fan suplay 5V from USB
                          • Gripen
                            • Sep 2020
                            • 37
                            • Slovakia
                            I give 5V to fan and fan is spinning the same way. What do I need to pay attention to?
                            • qayyum786
                              • Aug 2018
                              • 1933
                              • INDIA
                              is it noisy or what ?
                              • Gripen
                                • Sep 2020
                                • 37
                                • Slovakia
                                It sounds just as noisy. I don't think it should be like that by default.
                                Edit:I measure the fan wires.
                                Red wire 5V.
                                Yellow wire PWM signal(I think this is RPM signal).
                                Blue wire 0V, a few seconds after power on the laptop when the fan spins up then it is 3.3V.
                                • Gripen
                                  • Sep 2020
                                  • 37
                                  • Slovakia
                                  Hello.
                                  The laptop has been assembled, Windows 10 has been installed. The laptop has Intel HD 4000 and Nvidia GT740m. Only the Intel HD 4000 appears in Device Manager. The Nvidia Chip doesn't even heat up. There is no setting in the BIOS to disable it. I also tried updating the BIOS, it didn't help. It does not allow to install a driver because it do not find the Nvidia.
                                  Could it have to do with having a bios on it that you sent and not the original? Or need to look for the fault elsewhere?
                                  • razor_amd
                                    by razor_amd
                                    12-15-2020, 07:07 PM
                                  • grimacelord
                                    by grimacelord
                                    07-10-2025, 02:52 PM
                                  • throwaway327
                                    by throwaway327
                                    Model No: RC72LA
                                    Serial No: SBNVKD001014459
                                    06-18-2025, 05:52 PM
                                  • jbonavita
                                    by jbonavita
                                    Some issues
                                    Things I tried
                                    04-29-2025, 09:38 PM
                                  • lrouw84
                                    Asus vivobook s510ua bios changed to x510un
                                    by lrouw84
                                    Hi there,
                                    I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                                    I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                                    01-28-2023, 01:31 PM
