UX461UN REV 2.1 bios
  • shadow666
    • May 2017
    • 116
    • UAE
    Hello
    I Need Dump Bios
    UX461UN REV 2.1
    Regards
  • peste
    • Dec 2016
    • 13924
    • ROMANIA
    Re: UX461UN REV 2.1 bios
    Originally posted by shadow666
    Hello
    I Need Dump Bios
    UX461UN REV 2.1
    Regards
    post the original laptop bios
    • shadow666
      • May 2017
      • 116
      • UAE
      Problem This Bios is Randomm boot up laptop
      turn on but don,t anything on display and don,t turn off CAPS LOCK LED
      • shadow666
        • May 2017
        • 116
        • UAE
        There is no one to help me ?
        Backup Bios OR Clear ME !
        i Need This
        • lapfix
          • Mar 2020
          • 2764
          • my workshop
          i Need This
          Try and give feedback
          • shadow666
            • May 2017
            • 116
            • UAE
            Not Working Bro
            Friends Have Another Dump Bios?
            • tracker1
              • Jul 2017
              • 122
              • romania
              Not Working Bro
              Try
              • SCREAM76
                • Jan 2014
                • 55
                • istanbul
                I changed the cpu. The computer is displaying late and the fan is running at full speed. I tried clean me and I couldn't. original bios is attached please help me for celan me
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12441
                  Clear me file :
                  • SCREAM76
                    • Jan 2014
                    • 55
                    • istanbul
                    Originally posted by hoaca388
                    Clear me file :
                    thank you so much. the image is ok but the fan is still running at full speed even though the cpu temperature is normal.what could be the problem?
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12441
                      There are have two ME files, NPDM and YPDM. Try again with YPDM, good luck !
                      • SCREAM76
                        • Jan 2014
                        • 55
                        • istanbul
                        thank you but same problem. Fan full speed working
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12441
                          New bios with latest ME version.
                          If not working fine, try fine other problems.
                            • 22279
                            Post a picture of the square white QR code,near the USB-C port. Does the CPU have the same part number,did you replace it from a donor board
                            • Claudiomfa
                              • Nov 2015
                              • 455
                              • Portugal
                              try and report
                              • Maxpower3
                                Bad Veteran
                                • Feb 2018
                                • 1372
                                • France
                                always respecting mechanics.
                                dodgy repair
ID:	3674076 Click image for larger version
                                • Ahari
                                  by Ahari
                                  I...
                                  08-13-2025, 06:12 AM
                                • mkdj
                                  by mkdj
                                  Dear all,
                                  10-19-2025, 04:41 AM
                                • Habble7
                                  by Habble7
                                  Suspected Cause:
                                  Troubleshooting Attempts:
                                  05-22-2025, 07:28 AM
                                • haitham sharabati
                                  [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                  by haitham sharabati
                                  Hello engineers 😀,
                                  I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                  🔧 Device Info:
                                  - Model: HP 15-da2007ne
                                  - Product Number: 8XF55EA#ABV
                                  - Serial Number: CND0338P0D
                                  - CPU: Intel Celeron N4000
                                  - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                  💀 Problem:😅
                                  - Device shows “Administrator Password”...
                                  08-07-2025, 04:54 AM
                                • Citymin
                                  by Citymin
                                  S/N : 5RNK9FFT70...
                                  08-05-2025, 05:12 AM
