help me lenovo x250 power on and black screen
https://www.badcaps.net/donate -
Re: help me lenovo x250 power on and black screen
Issue no display lenovo x250 I have tried the bios uploaded in this thread none works.
Original backup attachedAttached FilesComment
Hello
power cut while updating lenovo x250 bios
now it won't open i would appreciate if you help me
nm-a091 rev 1.0Attached FilesComment
HI... I HAVE LENOVO X250.. how to remove x250 bios password??my bios file i is here........... thxxAttached FilesComment
BIOS guides, methods, resources and tools
https://www.badcaps.net/forum/showthread.php?t=103526
Password removal by laptop brand
https://www.badcaps.net/forum/showth...42#post1108842
Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
thank you...bios password is removed done..but hdd password is required to boot..how to remove?Comment
Hi, can anyone please help.
X250 can on, no display, 4 beeps error.
Type: Type 20CL-S18C0A
S/N: PC-0BBDSR
https://www.badcaps.net/donateComment
Re: help me lenovo x250 Whitelist
hi, I'm not good at programming, help me make a BIOS for a different Wi-FiAttached FilesComment
can you repair this bios? beep 4x short
i'm try many bios, but slow boot at allAttached FilesComment
Read the rules before posting
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
X250 Laptop (ThinkPad) - Type 20CL
Attached Files↵
YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
I also changed the screen because the PC fell and the screen was broken.
I changed the battery with a new and original battery.
I also had corrosion/oxidation on the... -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by invertI want to fix a Lenovo Legion 5 15ACH6 laptop, the laptop turns on but the screen is black, GPU and CPU are cold.
Bios changed a few times, unfortunately it didn't help but it should have. Please help.
The hardware is AMD Ryzen 5 -
by master3112Hello everyone,
I have a Lenovo IdeaPad 5 15ALC05 NM-D701. When I press the power button, the fan comes on, the power button flashes but the screen remains black. The device has a current consumption of 0.7A. I only have a BoardWiever for the device and no schematic. I have already tried to rewrite the BIOS, but the behavior is the same.
I have checked all voltages and everything fits:
PU1901 LV5028RPC - works
PL6202 -5.08V
PL6201 - 3.32V
PL300 - 0.77V
PL2101- 1.8V
PL1901 - 0.77V
PL1902 - 1.8V
PL1903 - 1.21V
PL5601 - 1.10V... -
by andreslimboHi all,
I have a question about a Lenovo board (HS45Q - HS45S (NM-D891) - later I will update this with the exact Lenovo model number.
I'm not experienced at all, but I managed to get this laptop from someone that needed to get rid of it. He had a water bottle in his bag which started leaking.
The initial problem was that it didn't show anything on the display, but it did show stuff when I connected an external display.
I saw water damage around the lcd connector. After cleaning and checking all wires and lines, somehow during testing I managed to blow up IT8227....03-16-2025, 02:41 PM - Loading...
