HP Zbook 17 G6 password
  • procyone
    • Feb 2020
    • 13
    Can anyone clean ZBook 17 G6 bios password?
    Thanks in advance
  • procyone
    • Feb 2020
    • 13
    Thanks in advance
    SN: 5CD0481W64
    • rex98
      • Feb 2023
      • 1298
      • Mandaue CEBU, Philippines
      Thanks in advance
      here
      • procyone
        • Feb 2020
        • 13
        I've tried RCUnlocker and hpunlocker and they don't work. Still asking for BIOS Administrator Password.
        • elbtonet
          • Nov 2019
          • 106
          • albania
          Hi friend. I have zbook 17 g6 Laptop with.
          SN 5CD9500LVH
          ProdId 6CK23AV
          And need to remove "hp endpoint security controller problem"
          • minhdigital
            • Nov 2022
            • 766
            • Vietnam
            #26
            SN 5CD9500LVH
            ProdId 6CK23AV
            Send to you
            • KVChippy
              • Apr 2024
              • 7
              #27
              Good Morning All
              Currently working on zBook 17 G6 after fixing so many myself I've come stuck with this one.
              Bios Chip was Blank when I Bought it. I flashed a BIN file from here which worked but serial mismatch threw up the Security Error.
              I'm not experienced enough to edit the semi working BIN file and add the right serial. So I was hoping someone on here could use HP Recovery BIN, embed my serial and give me back a Bios and EC Bin please.
              SN - 5CD0404K8R
              This is the serial from the back case. I haven't looked into the EC Chip for Serial as I get a read Error at 97%
              Many Thanks
              • peste
                peste commented
                Editing a comment
                post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
            • KVChippy
              • Apr 2024
              • 7
              #28
              Can anyone help at all please? I'm still struggling trying to fix this damn laptop 😁
                • 22419
                What model is your programmer, and the software version
                • KVChippy
                  • Apr 2024
                  • 7
                  #30
                  Hi Thanks for the reply.. Its the RT809F programmer, software version is 20240116
                  I've repaired 4/5 laptops since my original post. I've also wiped the EC chip when I thought I had a working bios/EC combo.
                  • volinakis
                    • Jan 2021
                    • 2887
                    • N/A
                    #31
                    post working bios files for both main+Ec, not the bin file from update package. But ... if you can boot in windows use BCU (bios config utility) from HP and use it under cmd as Admin to get current configuration using cmd line "biosconfigutility /get:config.txt" (or whatever name you want for.txt file), open it with notepad, make modifications for serial, sku, etc. - you have a sticker on bottom case with these values or go to partsurfer.hp.com enter your serial and get values from there if you can't find sticker - save file as new.txt (or whatever name you want) in docs and move it in BCU folder. then use cmd line " biosconfigutility /set:new.txt " and job done.
                    • KVChippy
                      • Apr 2024
                      • 7
                      #32
                      Hi thanks for the reply.
                      I went through so many different Bios files before I found one that kind of worked. But threw up the Endpoint Security Error. I know I should have saved it under a different file name but stupidly I Didn't.
                      I'm unable to read the EC chip as it errors at 97% no matter what I try.
                      I read somewhere that the Downloadable Bios file was able to be split into Bios and EC chip. Both with no Serial Numbers on
                      I'll try this weekend again to try and get it working to the Endpoint Security Error and post that Bios. I'm not able to get into Windows because of the error
                      Many Thanks
                      • compuline
                        • Jun 2023
                        • 38
                        • egypt
                        #33
                        Hello guys, I have an HP ZBook 17 G6, and the HP Endpoint Security message appears. I want to remove this message
                        • peste
                          • 14036
                          • ROMANIA
                          #34
                          post S/N, full name and model, motherboard model, product number,etc.
                          • compuline
                            • Jun 2023
                            • 38
                            • egypt
                            #35
                            HP ZBook 17 G6 Mobile Workstation Bundle (1C4Z4UC)
                            HP ZBOOK G6 17 DAXW3EMBAF0 Rev F
                            SN/2TK04905BZ
                            • lapfix
                              • Mar 2020
                              • 2764
                              • my workshop
                              #36
                              SN/2TK04905BZ
                              Just re-enter Your DMI in bios.
                              • compuline
                                • Jun 2023
                                • 38
                                • egypt
                                #37
                                This file is not working, my friend.
                                • techrecycle
                                  • Jan 2024
                                  • 65
                                  • england
                                  #38
                                  PLEASE HELP TO REMOVE BIOS
                                  SR : 5CDO11HX19
                                  THANKS IN ADVANCE
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12520
                                    #39
                                    SR : 5CDO11HX19
                                    THANKS IN ADVANCE
                                    Why do you want to remove bios ?
                                    • techrecycle
                                      • Jan 2024
                                      • 65
                                      • england
                                      #40
                                      sorry i mean bios password remove
                                      SR : 5CDO11HX19
                                      thanks
                                      • snpetit
                                        Asus FA706IH Bios Password remove
                                        by snpetit
                                        i need some help :-/
                                        i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
                                        Could you please remove all password related stuff from this bios. A hate Asus....
                                        Thanks in advance!...
                                        01-10-2025, 09:17 AM
                                      • traxformania
                                        TONGFANG "GM7TG7P" Bios Password Problem?
                                        by traxformania
                                        I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                        But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                        I'm trying to reset my bios without success.
                                        I tried :
                                        -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                        11-15-2023, 07:32 AM
                                      • zlr8r
                                        Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
                                        by zlr8r
                                        Greetings
                                        I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
                                        Serial Number: 5CG3202C16
                                        Product #/SKU: 739P0AV
                                        CT Number: PRTUE00WBI30YX
                                        Description: HP ZBook Firefly 14 inch G10
                                        BuildID: 23WWWGAZ602#SABU#DABU
                                        Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
                                        MAC address not found.
                                        • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
                                        10-28-2025, 01:56 PM
                                      • CanukTuk
                                        Beginner Tutorial for using RCUnlocker to remove BIOS password?
                                        by CanukTuk
                                        Kinda new to this, so hoping you will all give me a bit of a pass.
                                        I came to this forum because need to remove the BIOS password on an HP EliteBook 850 G1.
                                        I understand that I need to dumpt the BIOS to a dump file, process the dump file with RCUnlocker, then write the modified BIN file back to tthe BIOS chip.
                                        Is there a beginner guide anywhere that describes the entire process for doing this?
                                        I am reallly in the dark regarding which tool or tools are required to extract the BIOS dump file, then write the modified BIN back to the BIOS chip. The guides I have...
                                        03-24-2024, 02:54 PM
                                      • Nopslide
                                        HP Omen 15-dh0052nf power-on & bios password
                                        by Nopslide
                                        Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                        My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                        Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                        04-01-2024, 04:27 PM
