hp elitebook 850 g5 bios password
  • osman68i
    • May 2015
    • 354
    • The Netherlands
    Re: HP Elitebook 850 G5 Bios Password removal
    works perfect,
    thanks
    • babanu
      • Jan 2011
      • 61
      Re: hp elitebook 850 g5 bios password
      Hello, I have an HP Elitebook 850 G5 with a bios password
      I wrote the two memoirs I wrote the two memoirs with the dumps posted
      but I have many errors
      Sistem is booting in manufacturing program mode and the laptop starts up very hard
      I also solved errors with the HP MANUFACTURE PROGRAMMING MPM application
      there are two left SISTEM BOARD 00A FEATURE BITE and FACTORY HOST BASED MAC ADRESS
      I also post the 2 original saved dumps
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        File & instructions sent.
        Test & leave feedback.
        Become a Badcaps supporter
        Thanks to all supporters.​
        • babanu
          • Jan 2011
          • 61
          Hello !!
          I wrote the two memoirs and everything works fine !!!
          Thank you very much for your help
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            Hello !!
            Good for you. You did a good job too.
            Bravissimo
            • Crizby
              • Mar 2018
              • 12
              • N/A
              #26
              I also have the same errors as Babanu after reprogramming the bios.
              Any chance you could send me the instructions to fix it please.
              Do you need my Bios dump?
              • DECODERMAN
                • Aug 2022
                • 5
                • Milano
                #27
                hi, kindly can you help me, bios elitebook 850 g5 locked with password.
                thank you
                • peste
                  • 13853
                  • ROMANIA
                  #28
                  thank you
                  use RCUnlocker on the 16MB chip
                  • DECODERMAN
                    • Aug 2022
                    • 5
                    • Milano
                    #29
                    Thank you for your reply and for your interest, before proceeding as you indicated, I forgot to mention that the password is in the Power-On Authentication, so the procedure you gave me, is it okay to unlock? or is there other procedure?
                    Thanks again
                    • peste
                      • 13853
                      • ROMANIA
                      #30
                      Thanks again
                      post the 16MB bios here..
                      • O.Szilard
                        • May 2019
                        • 163
                        • hungary
                        #31
                        Hello! I would like to request the HP 850 G5 password to be deleted. I used RcUnlocker, but I couldn't remove the password (what could I have done wrong?) Thank you for your help!
                        • DECODERMAN
                          • Aug 2022
                          • 5
                          • Milano
                          #32
                          Thank you
                          • peste
                            • 13853
                            • ROMANIA
                            #33
                            try..
                            • peste
                              • 13853
                              • ROMANIA
                              #34
                              Thank you
                              try..
                              • novator2007
                                • Oct 2016
                                • 15
                                • mumbai
                                #35
                                Hi All,
                                I have an Elitebook 850 G5 with Bios lock.
                                Tried 128mb dump with RCUnlocker, unlock - ok but after that NB does not start - FAN spin and no picture.
                                I can confirm that the unlock algorithm works fine,NVRAM is deleted(compared to new and unlocked dump).
                                Anyone have experience with this model?Maybe I need to modify the 256mb flash?
                                By comparing 840 G5 main dumps(locked/unlocked) I can see some difference in User Area(there "A.d.m.i.n.P.W...)...
                                Please help.
                                • O.Szilard
                                  • May 2019
                                  • 163
                                  • hungary
                                  #36
                                  try..
                                  Thanks! I will try it soon
                                  • DECODERMAN
                                    • Aug 2022
                                    • 5
                                    • Milano
                                    #37
                                    try..
                                    Thanks for the help, but unfortunately it doesn't work, the computer starts like a backup of the bios and then says "Security Device Problem" I click on "OK" and it takes me back to the "Power-On Authentication" screen where it asks me to put the password.
                                    Maybe it's my fault, because the dump I uploaded was not good, as I compared it with the other dumps and it was not the same, so I submit a new dump which I am sure is good as I did 3 new readings and they are all 3 identical.
                                    P.S. I use a CH341A because EZP2019 + does not recognize me the 25q128jv.
                                    What software version do you recommend for the CH341A?
                                    Thank you
                                    • peste
                                      • 13853
                                      • ROMANIA
                                      #38
                                      Thank you
                                      try these two tools..
                                      https://www.badcaps.net/forum/showpo...6&postcount=10
                                      https://www.badcaps.net/forum/showpo...04&postcount=7
                                      • Toxic9996
                                        • May 2022
                                        • 32
                                        #39
                                        plz bios password for hp 840-G5
                                        • peste
                                          • 13853
                                          • ROMANIA
                                          #40
                                          the password is in the 16MB chip...use RCUnlocker and unlock it yourself..be careful not to delete the original bios..
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • tlindi
                                            Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                            by tlindi
                                            Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                            >Read BIOS guides, methods, resources and tools
                                            Ack
                                            >Try the method at BIOS guides, methods, resources and tools before requesting help
                                            Ack
                                            >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                            python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                                            01-30-2025, 04:26 AM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
                                          • Wutru
                                            HP Elitebook 820 G4 BIOS repair assistance required
                                            by Wutru
                                            Hi guys,
                                            If someone would be able to provide some expertise, I'd be very grateful.
                                            BIOS Corruption - Cause
                                            So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                            After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                            09-06-2025, 10:32 AM
