asus ux331u bios
  • ben60
    • Sep 2020
    • 6
    • taiwan
    asus ux331u bios
    did anyone can help? i need asus ux331u bios, thanks!!
    • 21662
    Re: asus ux331u bios
    Post your bios backup .
    • ben60
      • Sep 2020
      • 6
      • taiwan
      backup bios is Asus Zenbook UX331CA.bin ,but it's not work
      • ben60
        • Sep 2020
        • 6
        • taiwan
        • Claudiomfa
          • Nov 2015
          • 455
          • Portugal
          try and report
          • ben60
            • Sep 2020
            • 6
            • taiwan
            thanks a lot,i will try and report later
            • ben60
              • Sep 2020
              • 6
              • taiwan
              the bios is on ,but the computer still can't working, maybe the cpu or other equpment is out of order, thanks anyway
              • ramrk
                • Feb 2019
                • 155
                • India
                Asus ux331u bios bin
                Ux331ual main board rev 2.0
                • peste
                  • 13422
                  • ROMANIA
                  Re: Asus ux331u bios bin
                  what's up with that?? what's your problem??
                  • ramrk
                    • Feb 2019
                    • 155
                    • India
                    No shutdown problem . Display off but always board power on issue
                    • bbanana
                      Father Land
                      • Oct 2021
                      • 164
                      • Vietnam
                      turn off fast startup first
                      • razor_amd
                        by razor_amd
                        12-15-2020, 07:07 PM
                      • grimacelord
                        by grimacelord
                        07-10-2025, 02:52 PM
                      • lrouw84
                        Asus vivobook s510ua bios changed to x510un
                        by lrouw84
                        Hi there,
                        I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                        I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                        01-28-2023, 01:31 PM
                      • ferah831208
                        help with bios decompose for Asus s5506ma
                        by ferah831208
                        I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
                        08-24-2025, 05:35 PM
                      • DynaxSC
                        by DynaxSC
                        06-14-2024, 03:49 PM
