6-71-m77c0-d14 gp bios dump please
  • didouche1200
    • Oct 2016
    • 352
    • 82679911441
    please
  • peste
    • Dec 2016
    • 12244
    • ROMANIA
    Re: 6-71-m77c0-d14 gp bios dump please
    please
    post the full name and model of the laptop and the original bios.
      • 20300
      he`s asked for this same bios 3 times already in 2 threads and 1 off topic post. The model is in the last thread https://www.badcaps.net/forum/showthread.php?t=88759 .
      CLEVO w761c - https://repo.palkeo.com/clevo-mirror/W76xC/
      • didouche1200
        • Oct 2016
        • 352
        • 82679911441
        Clevo w76c
        model number : W761c
        • didouche1200
          • Oct 2016
          • 352
          • 82679911441
          user and passwors not found
            • 20300
            User = repo password = repo
            • didouche1200
              • Oct 2016
              • 352
              • 82679911441
              thinks
              • didouche1200
                • Oct 2016
                • 352
                • 82679911441
                thank you
                the problem I have is that my pc does not turn on anymore so I need a dump if possible
                • didouche1200
                  • Oct 2016
                  • 352
                  • 82679911441
                  thank you very much
                  the problem is solved
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • DynaxSC
                    by DynaxSC
                    11-17-2023, 10:56 AM
                  • grimacelord
                    Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                    by grimacelord
                    This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                    Motherboard model number: DA0PAMB46A1 REV: A
                    Secondary motherboard model number: 0PAB
                    SKU: 685K4UA
                    Serial number is: 5CD3223BJP
                    Recently reflashed this laptop with latest BIOS and once...
                    05-07-2024, 08:06 AM
                  • DynaxSC
                    Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                    by DynaxSC
                    I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                    It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                    I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                    11-06-2022, 05:22 PM
                  • vinaypundith
                    Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                    by vinaypundith
                    I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                    So, I'm looking for a BIOS dump for this machine - a 16MB one....
                    08-03-2024, 12:32 PM
