6-71-m77c0-d14 gp bios dump please
  • didouche1200
    • Oct 2016
    • 354
    • 82679911441
    please
  • peste
    • 12371
    • ROMANIA
    Re: 6-71-m77c0-d14 gp bios dump please
    please
    post the full name and model of the laptop and the original bios.
      • 20477
      he`s asked for this same bios 3 times already in 2 threads and 1 off topic post. The model is in the last thread https://www.badcaps.net/forum/showthread.php?t=88759 .
      CLEVO w761c - https://repo.palkeo.com/clevo-mirror/W76xC/
      • didouche1200
        • Oct 2016
        • 354
        • 82679911441
        Clevo w76c
        model number : W761c
        • didouche1200
          • Oct 2016
          • 354
          • 82679911441
          user and passwors not found
            • 20477
            User = repo password = repo
            • didouche1200
              • Oct 2016
              • 354
              • 82679911441
              thinks
              • didouche1200
                • Oct 2016
                • 354
                • 82679911441
                thank you
                the problem I have is that my pc does not turn on anymore so I need a dump if possible
                • didouche1200
                  • Oct 2016
                  • 354
                  • 82679911441
                  thank you very much
                  the problem is solved
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • DynaxSC
                    by DynaxSC
                    11-17-2023, 10:56 AM
                  • grimacelord
                    Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                    by grimacelord
                    This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                    Motherboard model number: DA0PAMB46A1 REV: A
                    Secondary motherboard model number: 0PAB
                    SKU: 685K4UA
                    Serial number is: 5CD3223BJP
                    Recently reflashed this laptop with latest BIOS and once...
                    05-07-2024, 08:06 AM
                  • DynaxSC
                    Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                    by DynaxSC
                    I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                    It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                    I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                    11-06-2022, 05:22 PM
                  • TacticalFahrrad
                    [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                    by TacticalFahrrad
                    I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                    06-30-2025, 04:09 AM
