asus ux303la bios
  • emaghanim
    • Dec 2014
    • 129
    • egypt
    asus ux303la bios
    plz need asus ux303la i5 uma bios
    no backup bad eprom
    i will replace the eprom but need a bios dump
    thanks
  • lapfix
    • Mar 2020
    • 2626
    • my workshop
    Re: asus ux303la bios
    post your bad / corrupted backup
    • razor_amd
      by razor_amd
      12-15-2020, 07:07 PM
    • DynaxSC
      by DynaxSC
      06-14-2024, 03:49 PM
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • Anchar777
      ASUS P1412CE need BIOS DUMP
      by Anchar777
      Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
      06-26-2025, 03:39 AM
    • kcp0085
      Request BIOS dump for ASUS FA617NS-A16.R77600
      by kcp0085
      Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
      I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
      Specs:
      - ASUS TUF FA617NS-A16
      - CPU: AMD Ryzen 7
      - BIOS chip: Winbond W25Q16JVSIQ (2MB)
      If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
      Thanks in advance!​
      05-02-2025, 12:52 AM
