HP Probook 650 G2 mb code 6050A2740001-MB-A01 bios dump needed
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Guys i ha this HP Probook 650 G2 with mb code 6050A2740001-MB-A01
    i could not find bios for it. i foung only some bios with code AX1 not A01 and that not work
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Re: HP Probook 650 G2 mb code 6050A2740001-MB-A01 bios dump needed
    this is fcked up. only found him on paid sites
      • 21993
      Can you post your bios backup .
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3628
        • slovakia
        no. laptop came from another shop that dont do backup and flash bad bios
          • 21993
          There`s 2 different bios versions , N76 and N87 .
          Try these 2, both have clean ME firmware,but not confirmed working .The N76 one has had 69 downloads and no
          confirmation if its working or not.The same for N87 ,its had 54 so far,and no feedback whatsoever ..., typical
          N76 - post #19 https://www.badcaps.net/forum/showthread.php?t=55239
          N87 - post #17 https://www.badcaps.net/forum/showthread.php?t=65000
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3628
            • slovakia
            first not even light. second looks like the same the previous shop program/lights on, missing only one CPU voltage and no reaction to PWB/
            but second and the one from shop are reported by MEInject as faulty by less than 2 partitions
            is there any easy way to check dump consistency like with MEInject ?
              • 21993
              I don`t use MEInject because its crap. Try these newer ones.
              • nexttoyou
                nexttoyou commented
                Editing a comment
                THE BOTH FILE WORKS BUT AFTER PUTTING THE SYSTEM INFO ITS STILL SHOWING MACHINE IS NOT IN GOOD STATE HOW DO I CLEAR THE ERORR PLSEA I NEED HELP
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3628
              • slovakia
              dude u r my hero
              N87 is the one. Fan and LEDs now works normal and when attached display BAM. there are picture
              We need more people like u . I owe u
              U r trully SUPER MODERATOR
                • 21993
                You`ve made my day, thanks
                • kitor
                  • Apr 2019
                  • 47
                  • Poland
                  I had similar story, but I accidentally erased my eeprom.
                  650 G2 01.49 Rev.A N87 ME_CLEAN.BIN.zip was the fix for my 4c4t variant.
                  The only issue I have now is that it's missing Windows key (existing installation got confused, activation was just crashing with that ) so I have to modify it to add key. Fortunately I have other, scrap HP laptop that may be used as source of that.
                  • dihcar84
                    • Aug 2012
                    • 204
                    • morocco
                    Originally posted by smdflea
                    i don`t use meinject because its crap. Try these newer ones.
                    thank you soo much
                    • bruce972
                      • Aug 2014
                      • 3
                      • Croatia
                      Bios 650 G2 01.49 Rev.A N76 ME_CLEAN.BIN.zip confirmed working.
                      thank you
                      • jacospama
                        • Aug 2019
                        • 240
                        • Ghana
                        this worked(650 G2 01.49 Rev.A N76 ME._CLEAN) thank You
                        • O.Szilard
                          • May 2019
                          • 163
                          • hungary
                          Thanks, it works!
                          • JersonP
                            • Mar 2020
                            • 30
                            • mozambique
                            clean-me (no display)
                            • mansurtimurov77
                              • May 2021
                              • Russia
                              6050A3142001-MB-A01 remove password bios
                              6050A3142001
                              help me remove bios password
                                • 21993
                                Re: 6050A3142001-MB-A01 remove password bios
                                Originally posted by mansurtimurov77
                                6050A3142001
                                You must post the serial number,and try the available HP unlocking software posted in the forum, there`s HP Unlocker and RCUnlocker
                                You MUST:
                                Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
                                • beast4ever
                                  • Feb 2015
                                  • 174
                                  • egypt
                                  hp probook 652 g2 error feature byte
                                  6050a2740001-mb-a01
                                  BIOS has been charged
                                  https://www.badcaps.net/forum/attach...6&d=1599999605
                                  with this file
                                  Enter the serial number and everything
                                  But it is not accepted
                                  feature byte
                                  I ask my friends to edit the file
                                  Note that a backup copy is not available
                                  The information is deleted from the device
                                  • beast4ever
                                    • Feb 2015
                                    • 174
                                    • egypt
                                    Re: hp probook 652 g2 error feature byte
                                    6050a2740001-mb-a01
                                    with this file
                                    feature byte
                                    up
                                    • bajno
                                      • May 2017
                                      • 27
                                      • Bulgaria
                                      up
                                      Scan QR Code on the label, above the text. Sometimes a letter is not printed (the label is too short).
                                      • DynaxSC
                                        by DynaxSC
                                        11-17-2023, 10:56 AM
                                      • TacticalFahrrad
                                        [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                        by TacticalFahrrad
                                        I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                                        BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                                        I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                        06-30-2025, 04:09 AM
                                      • vinaypundith
                                        Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                                        by vinaypundith
                                        I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                                        So, I'm looking for a BIOS dump for this machine - a 16MB one....
                                        08-03-2024, 12:32 PM
                                      • James Maxwell
                                        HP DM1-4000er Bios Dump needed
                                        by James Maxwell
                                        I badly need bios dump for HP DM1-4000er,
                                        Model: HP DM1-4000er
                                        Motherboard: DA0NM9MB6D0 REV.D
                                        Product: QJ490EA#ACB
                                        Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                                        10-28-2024, 05:38 PM
                                      • mkdj
                                        by mkdj
                                        Dear all,
                                        10-19-2025, 04:41 AM
