x555ub 2.0 bios dump
  • vahitlafci
    • Nov 2019
    • 5
    • turkey
    Hello. I have a K555UB laptop. (i7 6500u, GT940m) It has x555ub bios and i think it is rev 2.
    Can you share bios dump of x555ub rev2.0 please?
    Thank you.
  • lapfix
    • Mar 2020
    • 2719
    • my workshop
    Re: x555ub 2.0 bios dump
    Post your old dump
    • vahitlafci
      • Nov 2019
      • 5
      • turkey
      Originally posted by lapfix
      Post your old dump
      Unfortunately, I don't have any backup. I bought the bios programmer after an unsuccessfull update (I think). But here is the link from the manufacturer: https://dlcdnets.asus.com/pub/ASUS/n...555UBAS304.zip
      • lapfix
        • Mar 2020
        • 2719
        • my workshop
        Try this and give feedback , post #22 : https://www.badcaps.net/forum/showth...t=65285&page=2
        • vahitlafci
          • Nov 2019
          • 5
          • turkey
          Hello. I've flashed it but it is still the same. I tried a few more bios before this and result is the same. The issue is power led is slightly on (Not fully on, brightness is too low) and there is no other feedback such as cpu fan or cpu heat. I think It might be a hardware problem. Do you have any idea that what problem cause it?
          Thank you.
          • peste
            • Dec 2016
            • 12698
            • ROMANIA
            try..
            • vahitlafci
              • Nov 2019
              • 5
              • turkey
              Originally posted by peste
              try..
              Hello. It is still the same.
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
              • grimacelord
                Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                by grimacelord
                This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                Motherboard model number: DA0PAMB46A1 REV: A
                Secondary motherboard model number: 0PAB
                SKU: 685K4UA
                Serial number is: 5CD3223BJP
                Recently reflashed this laptop with latest BIOS and once...
                05-07-2024, 08:06 AM
              • DynaxSC
                Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                by DynaxSC
                I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                11-06-2022, 05:22 PM
              • TacticalFahrrad
                [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                by TacticalFahrrad
                I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                06-30-2025, 04:09 AM
