Need Qosmio F60-10Z Bios pass remove
+ More Options
Posts
  • dmartins
    David M
    • Apr 2014
    • 197
    • Lisbon
    Hello ,
    I need someone who can help me with this dump , this dump is working but it have a password , can someone help me removing it?
    Thanks is advance
  • OmegaPrime
    • Jun 2020
    • 22
    • Bulgaria
    Re: Need Qosmio F60-10Z Bios pass remove
    Try this one , if info is gone , boot into windows and use THIS TOOL to restore.
      • 21571
      HP bios tools won`t work with a toshiba.
      • OmegaPrime
        • Jun 2020
        • 22
        • Bulgaria
        Yes (misstake), is the password removed ?
        • dmartins
          David M
          • Apr 2014
          • 197
          • Lisbon
          Hello , still the same with pass
          • dmartins
            David M
            • Apr 2014
            • 197
            • Lisbon
            Someone can help ?
              • 21571
              The pass is stored in the SMSC MEC chip .The password can only be removed by challenge response code or by swapping the MEC chip with a password free one from a donor board,they can`t be flashed as JTAG access is blocked.
              • dmartins
                David M
                • Apr 2014
                • 197
                • Lisbon
                @SMDFlea thanks in advance ,
                Its complicated to get the challenge code correct ?
                • dmartins
                  David M
                  • Apr 2014
                  • 197
                  • Lisbon
                  The challenge code is
                  G7Y77-4WPQ3-XY188-4N4BL-B5CP3
                  Someone can help ?
                  Many thanks
                  • evserv
                    • Jun 2014
                    • 360
                    • Russia
                    Response Code = 3Y9V0 - 4MVYT - K2F01 - DG080 - XC46J
                    Study this help carefully:
                    https://yadi.sk/i/KO7erzrYcdOeQw
                    • dmartins
                      David M
                      • Apr 2014
                      • 197
                      • Lisbon
                      @evserv can you help me again with another challenge?
                      When i restart my computer ir changes the Challenge code..
                      Challenge Code now is N1RL8-4HDJW-D3WWC-Y2FJ9-V5FP1
                      Many thanks
                      • evserv
                        • Jun 2014
                        • 360
                        • Russia
                        Response Code = 547P6 - V3LV8 - U0LQY - YRX5R - N1ENP
                        • dmartins
                          David M
                          • Apr 2014
                          • 197
                          • Lisbon
                          Many thanks @Evserv it works , you save my life !
                          • Akintunde
                            • Mar 2017
                            • 154
                            • Nigeria
                            @ evserv good day sir,please i need your help sir
                            This is the Challenge Code =BUP9A-5YXJA-03B85-VGY7Y-FQLTF
                            THANKS SIR
                            • Akintunde
                              • Mar 2017
                              • 154
                              • Nigeria
                              I mean Toshiba
                              • Ahari
                                by Ahari
                                I...
                                08-13-2025, 06:12 AM
                              • Habble7
                                by Habble7
                                Suspected Cause:
                                Troubleshooting Attempts:
                                05-22-2025, 07:28 AM
                              • haitham sharabati
                                [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                by haitham sharabati
                                Hello engineers πŸ˜€,
                                I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                πŸ”§ Device Info:
                                - Model: HP 15-da2007ne
                                - Product Number: 8XF55EA#ABV
                                - Serial Number: CND0338P0D
                                - CPU: Intel Celeron N4000
                                - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                πŸ’€ Problem:πŸ˜…
                                - Device shows β€œAdministrator Password”...
                                08-07-2025, 04:54 AM
                              • Citymin
                                by Citymin
                                S/N : 5RNK9FFT70...
                                08-05-2025, 05:12 AM
                              • DynaxSC
                                by DynaxSC
                                11-17-2023, 10:56 AM
