Need Qosmio F60-10Z Bios pass remove
  • dmartins
    David M
    • Apr 2014
    • 197
    • Lisbon
    Hello ,
    I need someone who can help me with this dump , this dump is working but it have a password , can someone help me removing it?
    Thanks is advance
  • OmegaPrime
    • Jun 2020
    • 22
    • Bulgaria
    Re: Need Qosmio F60-10Z Bios pass remove
    Try this one , if info is gone , boot into windows and use THIS TOOL to restore.
      • 20757
      HP bios tools won`t work with a toshiba.
      • OmegaPrime
        • Jun 2020
        • 22
        • Bulgaria
        Yes (misstake), is the password removed ?
        • dmartins
          David M
          • Apr 2014
          • 197
          • Lisbon
          Hello , still the same with pass
          • dmartins
            David M
            • Apr 2014
            • 197
            • Lisbon
            Someone can help ?
              • 20757
              The pass is stored in the SMSC MEC chip .The password can only be removed by challenge response code or by swapping the MEC chip with a password free one from a donor board,they can`t be flashed as JTAG access is blocked.
              • dmartins
                David M
                • Apr 2014
                • 197
                • Lisbon
                @SMDFlea thanks in advance ,
                Its complicated to get the challenge code correct ?
                • dmartins
                  David M
                  • Apr 2014
                  • 197
                  • Lisbon
                  The challenge code is
                  G7Y77-4WPQ3-XY188-4N4BL-B5CP3
                  Someone can help ?
                  Many thanks
                  • evserv
                    • Jun 2014
                    • 355
                    • Russia
                    Response Code = 3Y9V0 - 4MVYT - K2F01 - DG080 - XC46J
                    Study this help carefully:
                    https://yadi.sk/i/KO7erzrYcdOeQw
                    • dmartins
                      David M
                      • Apr 2014
                      • 197
                      • Lisbon
                      @evserv can you help me again with another challenge?
                      When i restart my computer ir changes the Challenge code..
                      Challenge Code now is N1RL8-4HDJW-D3WWC-Y2FJ9-V5FP1
                      Many thanks
                      • evserv
                        • Jun 2014
                        • 355
                        • Russia
                        Response Code = 547P6 - V3LV8 - U0LQY - YRX5R - N1ENP
                        • dmartins
                          David M
                          • Apr 2014
                          • 197
                          • Lisbon
                          Many thanks @Evserv it works , you save my life !
                          • Akintunde
                            • Mar 2017
                            • 154
                            • Nigeria
                            @ evserv good day sir,please i need your help sir
                            This is the Challenge Code =BUP9A-5YXJA-03B85-VGY7Y-FQLTF
                            THANKS SIR
                            • Akintunde
                              • Mar 2017
                              • 154
                              • Nigeria
                              I mean Toshiba
                              • Habble7
                                by Habble7
                                Suspected Cause:
                                Troubleshooting Attempts:
                                05-22-2025, 07:28 AM
                              • DynaxSC
                                by DynaxSC
                                11-17-2023, 10:56 AM
                              • grimacelord
                                Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                by grimacelord
                                This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                Motherboard model number: DA0PAMB46A1 REV: A
                                Secondary motherboard model number: 0PAB
                                SKU: 685K4UA
                                Serial number is: 5CD3223BJP
                                Recently reflashed this laptop with latest BIOS and once...
                                05-07-2024, 08:06 AM
                              • DynaxSC
                                Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                                by DynaxSC
                                I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                                It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                                I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                                11-06-2022, 05:22 PM
                              • TacticalFahrrad
                                [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                by TacticalFahrrad
                                I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                                BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                                I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                06-30-2025, 04:09 AM
