Need Qosmio F60-10Z Bios pass remove
  • dmartins
    David M
    • Apr 2014
    • 197
    • Lisbon
    Hello ,
    I need someone who can help me with this dump , this dump is working but it have a password , can someone help me removing it?
    Thanks is advance
  • OmegaPrime
    • Jun 2020
    • 22
    Re: Need Qosmio F60-10Z Bios pass remove
    Try this one , if info is gone , boot into windows and use THIS TOOL to restore.
      • 20888
      HP bios tools won`t work with a toshiba.
      • OmegaPrime
        • Jun 2020
        • 22
        Yes (misstake), is the password removed ?
        • dmartins
          David M
          • Apr 2014
          • 197
          • Lisbon
          Hello , still the same with pass
          • dmartins
            David M
            • Apr 2014
            • 197
            • Lisbon
            Someone can help ?
              • 20888
              The pass is stored in the SMSC MEC chip .The password can only be removed by challenge response code or by swapping the MEC chip with a password free one from a donor board,they can`t be flashed as JTAG access is blocked.
              • dmartins
                David M
                • Apr 2014
                • 197
                • Lisbon
                @SMDFlea thanks in advance ,
                Its complicated to get the challenge code correct ?
                • dmartins
                  David M
                  • Apr 2014
                  • 197
                  • Lisbon
                  The challenge code is
                  G7Y77-4WPQ3-XY188-4N4BL-B5CP3
                  Someone can help ?
                  Many thanks
                  • evserv
                    • Jun 2014
                    • 359
                    • Russia
                    Response Code = 3Y9V0 - 4MVYT - K2F01 - DG080 - XC46J
                    Study this help carefully:
                    https://yadi.sk/i/KO7erzrYcdOeQw
                    • dmartins
                      David M
                      • Apr 2014
                      • 197
                      • Lisbon
                      @evserv can you help me again with another challenge?
                      When i restart my computer ir changes the Challenge code..
                      Challenge Code now is N1RL8-4HDJW-D3WWC-Y2FJ9-V5FP1
                      Many thanks
                      • evserv
                        • Jun 2014
                        • 359
                        • Russia
                        Response Code = 547P6 - V3LV8 - U0LQY - YRX5R - N1ENP
                        • dmartins
                          David M
                          • Apr 2014
                          • 197
                          • Lisbon
                          Many thanks @Evserv it works , you save my life !
                          • Akintunde
                            • Mar 2017
                            • 154
                            • Nigeria
                            @ evserv good day sir,please i need your help sir
                            This is the Challenge Code =BUP9A-5YXJA-03B85-VGY7Y-FQLTF
                            THANKS SIR
                            • Akintunde
                              • Mar 2017
                              • 154
                              • Nigeria
                              I mean Toshiba
                              • Habble7
                                by Habble7
                                Suspected Cause:
                                Troubleshooting Attempts:
                                05-22-2025, 07:28 AM
                              • Citymin
                                by Citymin
                                S/N : 5RNK9FFT70...
                                Today, 05:12 AM
                              • DynaxSC
                                by DynaxSC
                                11-17-2023, 10:56 AM
                              • MDSI
                                HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                by MDSI
                                I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                Details:
                                Model : HP OMEN 17-an012nf
                                Motherboard Part Number : DAG3BAMBAF0 REV : F
                                Serial Number (S/N) : 5CD7280D51
                                BIOS chip : Winbond W25Q64VSIQ
                                Programmer : EZP2023+
                                Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                I already...
                                07-28-2025, 07:11 AM
                              • grimacelord
                                Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                by grimacelord
                                This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                Motherboard model number: DA0PAMB46A1 REV: A
                                Secondary motherboard model number: 0PAB
                                SKU: 685K4UA
                                Serial number is: 5CD3223BJP
                                Recently reflashed this laptop with latest BIOS and once...
                                05-07-2024, 08:06 AM
