hi i need bin bios hp 17-ca1061nr DUMBLE20-6050A3056601-MB-A01
Re: hi i need bin bios hp 17-ca1061nr
SN/ 5CG9246WXB thank you so muchAttached Filesif you find these attachements useful please consider making a small donation to the site
Bios extras update site HP..this model has three bios variants, yours is 085B3.Attached Filesif you find these attachements useful please consider making a small donation to the site
Last edited by peste; 08-23-2020, 08:36 AM.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
oky thanksAttached Filesif you find these attachements useful please consider making a small donation to the site
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by CityminHi all,
S/N : 5RNK9FFT70...-
by greeliddHi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...-
I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...-
- Loading...
