HP Probook 11 X360 G1 EE bios dump
  • Thangviet
    • Apr 2023
    • 9
    Re: HP Probook 11 X360 G1 EE bios dump
    Originally posted by Thangviet
    I think I managed to get a dump of my BIOS however, it is a little smaller than the "clean txe" bios posted here in previous post.
    Attached is my BIOS dump, does it have a password?
    thanks
    Could I please get a clean bios from the attached dump file?
    Thanks!
    • thampy
      • Dec 2022
      • 6
      I have flashed my HP ProBook x360 11 G1 EE with the clean bios and verified it is written correctly and device is now working.
      I still have MPM locked and cannot make any changes to fill in my DMI info using NbDmiFit or BiosConfigUtility, and UUID is all F's but with hyphens. When using the UefiMpmUnlock.efi it says HP MPM protocol is not present and using the FSMC.bin on a FAT32 drive renamed to SMC.bin is not giving any pop-up when holding windows+up arrow+down arrow.
      Am I doing something wrong? I could manually program in my DMI info if I knew exactly where to put each value in HxD.
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        #43
        Originally posted by thampy
        I have flashed my HP ProBook x360 11 G1 EE...
        Originally posted by RethoricalCheese
        Probook 11 g1 is a special snowflake.
        You need to use HP biosconfigutility to read bios config. Then use spi programmer to dump that bios. Clean TXE region. Program that new bios. Then use biosconfigutility to write back config.
        Become a Badcaps supporter
        Thanks to all supporters.​
        • thampy
          • Dec 2022
          • 6
          Originally posted by Vesko356
          I have the clean TXE from SMDFlea flashed to my chip and I am getting "Access denied" returncode="6" on every value I'm trying to change as you can see in the attached screenshot
          • anthony.8388
            • Jul 2023
            • AUSTRALIA
            #45
            Originally posted by SMDFlea
            try this bios .
            I have an HP 11 X360 G1 EE with a BIOS password as well. Can I use the BIOS file that you posted without a password for my laptop? Or do I have to create a backup BIOS file and send it to you for password removal? I would appreciate your help. Thank you very much!
            • peste
              • Dec 2016
              • 13747
              • ROMANIA
              #46
              post the original bios file of the laptop here..
              • munir100
                • Dec 2018
                • 188
                • uae
                #47
                hi every one i have probook 11 x 360 g1 ee how to add dmi info in this bios here is bios sn-5CG82360KH PROID Y3K68AV Bulid id 16WWAUDT601 Feature Byte 3X476J6Z6b7B7H7M7Q7W9AaBaQapaq auawbVbhcAdUdWdpdqeTgd.qE
                • jonyhdtv
                  • Mar 2021
                  • 18
                  Hi every one
                  i have probook 11 x 360 g1 ee I have a password in BIOS, I tried to use RCunlocker does not recognize the image to unlock and HP unlocker - generates a file unlock but i have black screen when i turn on laptop. Bellow dump Bios.bin
                  please info how to successfully remove the password from the BIOS I have a few more computers like this.​
                • peste
                  • Dec 2016
                  • 13747
                  • ROMANIA
                  #49
                  Originally posted by jonyhdtv
                  Hi every one
                  The bios posted does not have the password posted bios of 16MB...first write back the 8 MB bios and see if you still have an image..
                  • jonyhdtv
                    • Mar 2021
                    • 18
                    I understand, bin file downloaded from the Winbond 25Q64FW as in the photo, after restoring the image the message as in the photo. Any suggestion?
                    • peste
                      • Dec 2016
                      • 13747
                      • ROMANIA
                      #51
                      look for a 16MB chip on the board ..see on both sides
                      • Al-Umar
                        • Jan 2024
                        • 34
                        • Nigeria
                        #52
                        Nee bios file appear blue screen while installing OS.
                        HP probook x360 11 g1 ee
                        SN/ 5CG7254ZHQ
                        will be very glad if i could get it asap
                          SMDFlea commented
                          Editing a comment
                          Thread merged.Please make use of the forum search before posting to find related threads where you can post your request.You do not need to start a new thread every time.
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12420
                        #53
                        SN/ 5CG7254ZHQ
                        HP ProBook x360 11 G1 EE Base Model Notebook PC
                        ​https://www.badcaps.net/donate
                        • DProf.
                          • Jun 2018
                          • 100
                          • Nigeria
                          #54
                          PLS GREATE MINDS I NEED BIOS DUMP FOR HP PROBOOK X360 II G1 EE
                          BOARD NO AUTOBOT-6050A2881001-AM-A03
                          HSN-108C
                          PRODUCT ID 4PH15UP#ABA
                          S/N 5CG820730H
                          ATTACHED IS MY ORIGINAL BIOS DUMP
                          ISSUE PASSWORD
                          • messengertr
                            • Mar 2024
                            • 7
                            • Turkey
                            #55
                            Good day to all,
                            I lost the bios password of my device, the details of which are written below, I would be glad if you could help me read it.
                            HP PROBOOK X360 11 G1
                            PRODUCT ID 4BC72ES#UUW
                            SN# 5CG8263NN4
                              SMDFlea commented
                              Editing a comment
                              Thread merged with existing topic.
                          • danito
                            • Jun 2016
                            • 1151
                            • Romania
                            #56
                            Originally posted by messengertr
                            Good day to all,
                            SN# 5CG8263NN4
                            the other chip...
                            • messengertr
                              • Mar 2024
                              • 7
                              • Turkey
                              #57
                              I don't understand what you mean
                              thanks
                              • SuborQ
                                • Aug 2017
                                • 19
                                • Украина
                                #58
                                Please help, HP x360 SN:5cg7501751, BIOS password, if I write down my dam with a clean DXE, the password is deleted, but then I can’t edit the DMI, nothing works, maybe someone knows how to remove the password without clearing the DMI
                                • Zibbo
                                  • Mar 2017
                                  • 205
                                  • Zimbabwe
                                  #59
                                  Same thing here, did you ever find a solution?
                                  • hichamhb
                                    • Jun 2019
                                    • 94
                                    • morocco
                                    #60
                                    Device: Laptop
                                    Brand: HP
                                    Model: HP x360 11 G1 EE
                                    Board number: AUTOBOT-6050A2881001-MB-A03
                                    Serial number : 5CG932B3N6
                                    Request: BIOS REPAIR
                                    Issue: NO PICTURE​
                                  • Ahari
                                    by Ahari
                                    I...
                                    08-13-2025, 06:12 AM
                                    HP ProBook ProBook x360 11 G1 EE Notebook PC Notebook Specification for Upgrade or Repair
                                    This specification for the HP ProBook ProBook x360 11 G1 EE Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook x360 11 G1 EE Notebook PC boardview and ProBook x360 11 G1 EE Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                    09-06-2024, 06:40 AM
                                  • mkdj
                                    by mkdj
                                    Dear all,
                                    10-19-2025, 04:41 AM
                                  • Habble7
                                    by Habble7
                                    Suspected Cause:
                                    Troubleshooting Attempts:
                                    05-22-2025, 07:28 AM
                                    HP ProBook x360 Pro x360 Fortis 11 inch G9 Notebook PC Hybrid (2-in-1) Specification for Upgrade or Repair
                                    This specification for the HP ProBook x360 Pro x360 Fortis 11 inch G9 Notebook PC Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pro x360 Fortis 11 inch G9 Notebook PC boardview and Pro x360 Fortis 11 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                    09-07-2024, 05:50 AM
