Dell Latitude 5500 Bios password
  • Justice88
    • Jan 2025
    • 3
    Originally posted by Justice88
    I am in need of assistance making changes to the boot priority on a Dell Latitude 5500.
    A friend of mine gave me his laptop which began blue screening a few months ago, and now upon powering on the system, it is indicating that there is no bootable device.
    I suspect it would be a somewhat simple fix to get a new nvme drive and swap them out, if I am able to change the boot priority to a flash drive to install Windows.
    Alas, the password in the bios has got me stuck, and I need assistance in acquiring my golden ticket in the form of the bios administrator password.
    The service tag viewable in the BIOS is 4M1ZM13-8FC8.
    I did take a look at the 8FC8 patcher but I am under the impression that I won't be able to utilize that since I am not able to boot into Windows currently.
    Feel free to point me in the right direction if my assumption is incorrect - I am new to tinkering with premanufactured systems/laptops and the hurdles they put in the way, so excuse my ignorance.
    Thank you
    Just to update what I have done since posting and some things I had tried prior to my post I forgot to mention:
    I did open up the laptop and tried to reseat the NVME SSD which was installed, just to rule that out as a possible issue.
    Upon doing a little more research, it seems that the issue may be that the Dell system changing itself from UEFI to Legacy boot (this appears to be a somewhat common issue).
    I am not certain that explains the blue screens leading up to the current issue I am facing, but either way, I can't even verify if it's in Legacy or UEFI boot since the password prevents me to viewing it's current configuration, so my previous post and the help I am asking for still stands.
    Thank you
    Edit: While making this post (should have waited another few minutes) I was able to get into Windows installation through a USB boot drive, and the NVME drive is showing up, so I am not convinced entirely that it's dead all together. I am reluctant to immediately try reinstalling windows on it, in case the issue is the boot mode needing to be changed from Legacy, and I could avoid formatting the drive - which wouldn't be the end of the world if I had to. If I were to format the drive and install windows fresh on it, I am assuming that if the BIOS is set to Legacy, I would still be stuck in the same spot I am now anyway.
    • badcapszip
      • Mar 2023
      • 6
      • Europe
      #382
      Hi guys, could someone help to delete bios the password.
      Dell latitude 5500, model P80F.
      Service Tag-73FNL33.
      Two ic dump atached.
      Thanks in advance.
    • LBTT1121
      • Nov 2024
      • 544
      • Việt Nam
      #383
      Thanks in advance.
      hi, check and feedback
      • badcapszip
        • Mar 2023
        • 6
        • Europe
        #384
        Thank you, it,s working!
        • philogsm
          • Jan 2025
          • 4
          • România
          #385
          Hi everybody , if you can help me please to unlock BIOS pasword from dell laptop latitude 5500 , i attach the dump file from wson U5 chip
          ST: DDNRL13
          System Number DNRL13-8FC8
          Board Number: EDC50 LA-G901P Rev:1.0(A00)
          Thanks In advance​
          • LBTT1121
            • Nov 2024
            • 544
            • Việt Nam
            #386
            ST: DDNRL13
            Thanks In advance​
            hi, try and feedback
            • horizonrdf
              New OLD
              • Apr 2019
              • 15
              • tunisia
              #387
              plz remove password dell latitude 5500
              i have password dell latitude 5500
              MB edc50 la-g901p rev 1.0 (A00)
              S/N 4B80M13-8FC8
              UC5 bios (only chip UC6 is empty)
              thanks​
              • hoaca388
                Badcaps
                • Jan 2022
                • 11750
                #388
                S/N 4B80M13-8FC8
                thanks​
                Unlocked
                • horizonrdf
                  New OLD
                  • Apr 2019
                  • 15
                  • tunisia
                  #389
                  hi friend
                  the bios is unlocked but the screen go black after few minutes during the windows installation
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11750
                    #390
                    hi friend
                    Again
                    • horizonrdf
                      New OLD
                      • Apr 2019
                      • 15
                      • tunisia
                      #391
                      same problem my friend
                      only the first boot is ok
                      after that the screen go black when windows almost start
                      I think it's about bios region
                      • LBTT1121
                        • Nov 2024
                        • 544
                        • Việt Nam
                        #392
                        try
                        • horizonrdf
                          New OLD
                          • Apr 2019
                          • 15
                          • tunisia
                          #393
                          same problem
                          • LBTT1121
                            • Nov 2024
                            • 544
                            • Việt Nam
                            #394
                            same problem
                            check hardware....
                            • horizonrdf
                              New OLD
                              • Apr 2019
                              • 15
                              • tunisia
                              #395
                              the pc is already running with the old bios
                              I will change the boot order (locked ) in order to format it
                              • horizonrdf
                                New OLD
                                • Apr 2019
                                • 15
                                • tunisia
                                #396
                                pleeeez i need help !
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11750
                                  #397
                                  Try older version.
                                  • horizonrdf
                                    New OLD
                                    • Apr 2019
                                    • 15
                                    • tunisia
                                    #398
                                    programming failed
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11750
                                      #399
                                      programming failed
                                      Look the picture
Name:	2025-03-08 15_31_54-Mật khẩu Bios Dell Latitude 5500 - Badcaps.png
                                      • horizonrdf
                                        New OLD
                                        • Apr 2019
                                        • 15
                                        • tunisia
                                        #400
                                        what you mean freind
                                        this is a TL866 plus this location in zif socket is correct
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
                                          DELL Latitude 5500 Notebook 5000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 5500 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5500 boardview and 5500 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5500...
                                          09-06-2024, 12:13 PM
