LA-9865P BIOS+EC please
  • Spider1211
    • Oct 2019
    • 532
    • Mauritius
    Hey guys, grateful if anyone can provide known good Main BIOS + EC for Toshiba Satellite L40-A.
    Motherboard: LA-9865P rev 1A
    EC: KB9012QF
    Please find attached original main BIOS dump and another bios downloaded from (https://www.badcaps.net/forum/showth...ht=toshiba+L40). I will attach EC dump as soon as I dump it.
    Laptop issue:
    Laptop came in as no power. After initial diagnostics, a shorted input mosfet was found and replaced. Laptops then exhibits issue hereunder.
    when power button is pressed, board turns on (fan spins, hdd spins, etc but no display) and turns off after about 3-5seconds.
    No other shorts were found and all voltage rails seems to be present and stable when power button is pressed as well as stable 3.3V when off.
    upon first connection of charger, laptop idle draw is 21mA @19.7V. After first boot cycle (Off-On-Off), current draw drops to 8mA @19.7V.
    Laptop consumes 320mA at start-up and stabilize quickly to 261mA@19.7V.
    Laptop charges fine and exhibit same issue with AC only, Battery only & both AC + Battery. Any help is greatly appreciated.
  • Spider1211
    • Oct 2019
    • 532
    • Mauritius
    Re: LA-9865P BIOS+EC please
    Please find attached EC dump. Any help is greatly appreciated!
    • peste
      • 13661
      • ROMANIA
      try..
      • Spider1211
        • Oct 2019
        • 532
        • Mauritius
        Thanks peste, but unfortunately issue is still same. Most likely there are other issues on the board. Will open another thread for it.
        • Ahari
          by Ahari
          I...
          08-13-2025, 06:12 AM
        • mkdj
          by mkdj
          Dear all,
          10-19-2025, 04:41 AM
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • Mephysis
          DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
          by Mephysis
          Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
          I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
          03-27-2025, 02:34 AM
        • dell_bios
          Need unlocked BIOS dump for W25Q64FV (Admin Password removal)
          by dell_bios
          I'm working on removing an administrative BIOS lock (Supervisor/Admin Password) on a laptop.
          The board has three SPI flash chips:
          - W25Q64FV (main BIOS)
          - W25Q32FV (EC/TPM)
          - W25X10CL (configuration)
          I was able to read the dump from the W25Q64FV chip, CRC32 = 0x3DE23E27.
          The dump contains protection that needs to be removed.
          If anyone has a clean or unlocked BIOS dump for W25Q64FV, I’d really appreciate it!
          I’m also happy to share my dump for comparison if needed.
          Laptop model: [please specify, e.g....
          10-16-2025, 04:28 PM
