  • Linux200
    • Sep 2020
    • 12
    • Algeria
    #1221
    Is it possible that the Intel ME region on the original bios is defective.
    Lenovo boot screen starts slowly.
    I had the problem once too.
    https://www.youtube.com/watch?v=aHSP...nnel=SureCanDo
    Hi thanks for your reply
    Original bios start normally and very faster
    My problem is when i patch bios it wont start to boot
    • AAAC
      • Jan 2020
      • 457
      • Mexico
      #1222
      @Linux200
      I suggest to read the instructions in post #1 of this thread, with the patched bios you will have to power-on the laptop and after it shows LENOVO splash screen, immediately press appropriate key to go into Setup/BIOS (press F1 key). Then follow the instructions.
      If the laptop does not respond to F1 key press, then most likely it does not have a Supervisor Password set, but you can use a locked hard drive to make the patched file to work and to deactivate CompuTrace (if active).
      • Linux200
        • Sep 2020
        • 12
        • Algeria
        #1223
        Originally posted by AAAC
        @Linux200
        hi thanks for reply it doesn't show spalsh screen after patching bios with or without a locked drive inside
        but with original bios laptop work fine with a locked supervisor enabled ;-(
        can someone send a patched bios with other methode plz
        • NMIRKO
          • Feb 2018
          • srb
          #1224
          Lenovo yoga s1 administrator pasword please la-a341p motherboard
          • 999Alibaba
            • Jan 2022
            #1225
            Originally posted by hoaca388
            [ATTACH]253780[/ATTACH]
            The binary is the same with my one generated in Linux with python 3.9...So is not helpful. Thank you, anyway for your help.
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1153
              • France
              #1226
              24rf08 eprom normaly or may be flash kb9022
              patch not work
              • Genova
                • Jan 2020
                • 116
                • FRANCE
                #1227
                Hi guys,
                can someone provide me with 2 "cleaned bios" for t440p i lost my .bin files..
                  • 20279
                  Originally posted by Genova
                  Hi guys,
                  There are a few "t440p" bios request threads already, find one of those to post in if youre not asking for Password Removal.
                  • Genova
                    • Jan 2020
                    • 116
                    • FRANCE
                    #1229
                    Already try with them on this post : https://www.badcaps.net/forum/showpo...7&postcount=12
                    but no positive result
                    • Markus1741
                      • Sep 2020
                      • 842
                      • N/A
                      #1230
                      Try ...
                      • Genova
                        • Jan 2020
                        • 116
                        • FRANCE
                        #1231
                        Try ...
                        Perfect thank you
                        • minuch
                          • Jan 2022
                          • Russia
                          #1232
                          Thank you friend! Removed password on Lenovo A475.
                          • x3oo
                            • Jan 2022
                            • 8
                            • austria
                            #1233
                            How do i save the original bios?
                            • Phatzy
                              • Jan 2022
                              I have an Lenovo ThinkPad Yoga 260 and is password locked to bios.
                              I did repair this laptop after it had a failed coil.
                              With this model can I just reprogram the bios chip or does it require special software to remove the password? so I can boot the laptop and verify all conditions are fully working.
                              • Maxpower3
                                Bad Veteran
                                • Feb 2018
                                • 1153
                                • France
                                #1235
                                save original , use patcher and after put back your original bios
                                • x3oo
                                  • Jan 2022
                                  • 8
                                  • austria
                                  #1236
                                  how do i save it?
                                  • markwm
                                    • Jan 2022
                                    Hi All
                                    I've read through the entire thread and researched other web pages and given this a go. Unfortunately when I try and boot after writing the patched bios nothing happens. Laptop won't turn on at all. I've tried disconnecting batteries (CMOS and main) nothing.
                                    I've tried to write the original dump back to the chip, nothing
                                    I've obviously done something wrong. Any advice?
                                    Lenovo Yoga 260. Original Dump attached.
                                    I've used CH321A with AsProgrammer
                                    Any advice gratefully received. Cheers
                                    • Markus1741
                                      • Sep 2020
                                      • 842
                                      • N/A
                                      #1238
                                      Originally posted by markwm
                                      Hi All
                                      Write this file back maybe that helps.
                                      Original File ME Clean Region.
                                      Try ...
                                      • ayaabdoulah
                                        • Oct 2019
                                        • maroc
                                        #1239
                                        Thinks
                                        • markwm
                                          • Jan 2022
                                          Try ...
                                          Hi, thanks for your help. I've tried writing that to the chip. Once written I've tried to verify and get the following
                                          Verify memory...
                                          Verification error on address: 00000019
                                          Execution time: 00:00:00
                                          Laptop still won't respond when I tried to boot. No beeps, no lights, nothing.
                                          I think I may have broken something but not sure what. Could it be the bios chip is fried?
                                          Not sure where I've gone wrong. I dumped the original 3 times and compared them, they're all fine.
                                          I've successfully patched the original.
                                          I've tried programming the chip with the patched bios, the original bios, other patched bios's from this forum but I get nothing...
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • Bloodhoundje
                                            by Bloodhoundje
                                            03-16-2024, 03:12 PM
