Thanks for sharing.
I tried the file you shared,
I wrote it and verified it was written correctly.
It has the same problem as above: it beeps 5 times twice, the fans spin for a few seconds, and then shuts down. No signal.
rewriting my original, it goes back to how it was before with the password.Comment
Hello friends! I used autopatcher, rewrote the patched file in the bios, but as a result, when I press the power button, it blinks 3 times. Then nothing happens. Can someone help?
Laptop Lenovo P50
Type 20EQ
Serial MJ-04TPLTComment
STEP 1: Flash and replace current BIOS with the P50_Bios_2_PATCHED.bin file
STEP 2: Boot the machine
STEP 3: Press ENTER/F1/etc. to enter BIOS settings
STEP 4: Enter any character when asked for Supervisor Password
STEP 5: Press enter when it shows Hardware ID
STEP 6: Press space bar 2x when asked
STEP 7: Turn off machine
STEP 8: Restore original P50_Bios_1.bin BIOS content
STEP 9: Reset BIOS settings to factory default
Good luck!Attached FilesComment
Flashing both chips back to their original states doesn't even fix it, it no longer boots at all after trying the PXE driver injector method...
The 25Q80 chip is your PD controller SPI so must be untouched and write it back as is.
Write the content from the attachment and tell me if it works or not.
It's tested by me on several T470s laptops.Attached FilesComment
I flashed it just now, it still does the same thing. The keyboard and power button light up briefly then it shuts off. This happens once when power is plugged in, then it is unresponsive until unplugged and plugged back in once more.Comment
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
