  • Gunat360
    • Sep 2025
    #3941
    Originally posted by peste
    post S/N, full name and model, motherboard model, TYPE,etc.
    Thanks for the reply!
    P/N: SL10Q67064
    S/N: PF-1FC02J
    Lenovo ThinkPad-T480-TYPE-20L5-20L6
    Factory: JVHFC1
    MTM: 20L6S08H1A
    BIOS Chip: WinBond 25Q128JVSQ 128
    Advice on how to get motherboard model, as the system does not boot? Thanks!
    • fabian_457
      • Dec 2015
      • mexico
      #3942
      HELLO!! Can you help me remove the password? I've tried lenovo_autopatcher but it doesn't work. Serial Number: PW-05DRJP MODEL: ThinkPad L14 Gen 3, LG4 LT5 ADL RT UMA MB 223030-1. 448.0PZ80.0011
      BIOS ATTACHED. THANKS, COLLEAGUES.
      • elianadragon
        • Sep 2025
        Hello! I tried using the autopatcher for my Lenovo T480s, but it only causes the system to beep and display a blank screen (sometimes a very dimmed Lenovo logo). I'm using AsProgrammer and have followed the main instructions in this thread. I have also tried the W25Q128JV@SOIC8_PATCHED.bin file.
        I've attached my original bin file.
        Lenovo Thinkpad T480s
        TYPE NUMBER: 20LS-002CUS
        S/N: PC-0Y188A
        Bios: Winbond W25Q128JV5Q
          • 21861
          EC chip is NPCX997 ? https://www.badcaps.net/forum/troubl...95#post3592395
          • Karol
            • May 2016
            • 90
            #3945
            Are you sure you didn't do any faults to the motherboard ?
            Program back the backup, see if you have POST
            Joe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.
            • Stefan Steff
              • Mar 2024
              • 357
              #3946
              S/N: PC-0Y188A
              OK, let's see if my method works for you...
              STEP 1: Flash and replace current BIOS with the attached Lenovo ThinkPad T480s_PATCHED.bin file
              STEP 2: Boot the machine
              STEP 3: Press ENTER/F1/etc. to enter BIOS settings
              STEP 4: Enter any character when asked for Supervisor Password
              STEP 5: Press enter when it shows Hardware ID
              STEP 6: Press space bar 2x when asked
              STEP 7: Turn off machine
              STEP 8: Restore your saved Original.bin BIOS
              STEP 9: Reset BIOS settings to factory default
              Good Luck!
              • dustin_echoes
                • Sep 2025
                #3947
                Good Luck!
                I had the same issue as elianadragon when using autopatcher (T480s, S/N PC-1678ZZ, w25q128jv). I tried your patched version and worked perfectly. Thanks!
                • elianadragon
                  • Sep 2025
                  I've tried reprogramming the backup, and I can enter the BIOS again with that. The screen is still very dim with it. (might be backlight, but I am using a brand new screen)
                  • elianadragon
                    • Sep 2025
                    Good Luck!
                    Thank you for responding!
                    After I flashed this file, I pressed F1 and got four beeps. Then it shows a faint "Entering Setup" on the screen and hangs there.
                    • Stefan Steff
                      • Mar 2024
                      • 357
                      #3950
                      Flash your original BIOS again and check if the laptp starts ok and you can get to the Password screen.
                      If it's ok then flash the patched file and try again all steps from the beginning
                      • mariusdumi
                        • Sep 2025
                        • 7
                        • Italia
                        #3951
                        I'm trying to remove the bios Password from my ThinkPad P50.
                        I have tried both lenovo_autopatcher_0.2 and the older lenovo_autopatcher.
                        In both cases the generated files (P50BK1_PATCHED_CLEAN and P50BK1_PATCHED) do not work.
                        After flashing I only get a black screen, 5 beeps, fans stop spinning, and no other signs of life.
                        I am not able to manually edit the NVRAM (VSS2 store) blocks with UEFITool.
                        **Tools available:**
                        - Windows 11
                        - CH341A PRO (2 units)
                        - AsProgrammer
                        - 3 original BIOS dumps (compared with HxD, all identical)
                        **Motherboard:**
                        - Lenovo BP500 NM-A451 Rev 1.0 (2015-11-06)
                        - BIOS chip: Winbond W25Q128FV
                        - Machine: ThinkPad P50, TYPE 20EQ-S3WF12, S/N PC-0GSV94 16/11
                        I know that many users face the same issue (after autopatcher → 5 beeps and black screen).
                        Has anyone already found a working patch for the P50, or could you help me clean the dump manually?
                        Thanks!
                        • floppy1
                          • Sep 2025
                          • Tajikistan
                          #3952
                          I need a patched BIOS version for X1 Yoga 4th generation. Autopatcher did not help, the laptop beeps many times, and the screen remains black.
                          MB: NM-B861
                          Type: 20QG-S4K100
                          Serial: PF-2622VP
                          Thank you
                          • ahmed33essawy
                            • Jul 2017
                            • 7
                            • egypt
                            #3953
                            Can you patch this file for x480
                          • ahmed33essawy
                            • Jul 2017
                            • 7
                            • egypt
                            #3954
                            Need bios supervisor pass patch file
                            Thinkpad X1 carbon Mb nm-b481 rev:1
                            Factory id JVHFC1
                            • Karol
                              • May 2016
                              • 90
                              #3955
                              OK
                              Than connect an external HDMI screen for better view, and keep pressing the F1 key when start with the patched file. If you delay with F1 key it freeze in Lenovo screen.
                              • Karol
                                • May 2016
                                • 90
                                #3956
                                Originally posted by mariusdumi
                                - Windows 11
                                - AsProgrammer
                                **Motherboard:**
                                Thanks!
                                Test this patched file.
                                • Karol
                                  • May 2016
                                  • 90
                                  #3957
                                  MB: NM-B861
                                  Type: 20QG-S4K100
                                  Serial: PF-2622VP
                                  Thank you
                                  Your model can be unlock if you provide 2kb file EEPROM container from MEC1663
                                  No main BIOS patch available for your model
                                  • bear_2007
                                    • Aug 2025
                                    • 7
                                    • Україна
                                    #3958
                                    I flashed it with autopatcher, it stopped starting, can someone help? L590 nm-b931 ec ite8227e
                                      • 21861
                                      Does this it have a model number ? .Does it start if you flash the old bios back
                                      • bear_2007
                                        • Aug 2025
                                        • 7
                                        • Україна
                                        #3960
                                        Dump original
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • pirati
                                          by pirati
                                          Yesterday, 04:20 PM
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
