Tried Neoprogrammer same thing see screen shot. I tried running the patch again but same thing. Only works when writing the original bin. Can you help.[/QUOTE]
Difference between files is a Padding sized 16777216 bytes, after Bios_Region. Try removing it. Post Serial no. as in rules of this forum and I'll try to help.
Last edited by volinakis; 03-20-2025, 05:49 PM.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
there is no letter "O" in serial no. just 0 (zero)
Try this file.Attached Filesif you find these attachements useful please consider making a small donation to the site
Thank you so mush. Been able to remove password on second hand A475.
Did that on Linux Mint though, as the script refused to do anything on Windows even though Python 32 and 64 was installed (tried on two laptops one with fresh install)Comment
Looking for me region repository file
11.8.93.4323
try this file and follow steps from autopatcherAttached Filesif you find these attachements useful please consider making a small donation to the site
I just managed to unlock the supervisor password on my T480s.
PC model: 20L7001NMZ
Motherboard: NM-B471
BIOS chip: WINBOND 25Q128JVSQ
I used a CH341A with an 8-pin clip directly on the chip (soldering isn't my thing).
I used NeoProgrammer v2.2.0.10 because I couldn't find my chip in either CH341A Programmer or ASProgrammer.
Using the 8-pin clip that comes with the CH341A was a real pain — I think there were contact issues, and I had to reposition the clip several times before NeoProgrammer could detect the chip. It took quite a while each time I wanted to connect it, but eventually, it worked.
It wasn't smooth sailing; I ran into a few problems. Honestly, I don't fully understand what I did, but in the end, it worked! Here's a step-by-step of what I did:- Backed up the original BIOS chip to a .bin file
- Ran the autopatcher script, which created a "_PATCHED" .bin file
- Erased the chip and wrote the patched file
- Turned on the computer
At this point, the laptop started beeping weirdly (beeps with different noise levels 5 or 6 times) with a black screen, then shut down.
Tried this a few times — same result every time.
5. Flashed back the original BIOS file — the laptop was back to its initial state. Not bricked, thankfully.
A bit desperate, I tried something else, not really knowing what I was doing:- Downloaded the BIOS file shared by Stefan Steff on this thread (4th post) :
https://www.badcaps.net/forum/troubl...20l8-bios-dump - Booted the PC with that BIOS file — it struggled a bit, rebooted once or twice, then asked for the Supervisor Password
- Exported the BIOS from the chip again and compared it to the original Stefan Steff file — it had changed
- Ran the autopatcher on this new BIOS file, then flashed the patched version to the chip
- Followed the patch usage procedure:
- Boot the machine
- Press ENTER/F1/etc. to enter BIOS
- Type any character for the Supervisor Password
- Press Enter when the Hardware ID shows
- Press Space twice when asked
- Power off - Finally, I reflashed Stefan Steff's BIOS file — and voilà: no more Supervisor Password, and the PC works perfectly.
Don't ask me why I followed this exact process — I'm not sure myself — but it worked for me.
Hope it helps someone!Comment
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by piratiHello everyone,
Product ID: RZ09-0421
Motherboard: CH580
Bios File Size: 32,768 KB
Dear Forum Readers!
!!! MY RAZER BLADE...-
11-24-2025, 05:52 PM -
- Loading...
