how to create a lenovo laptop bios dump file
 there are several ways of accomplishing this, you can use a mini programmer to read the chip while on board or remove the chip and place it in the programmer and dumb the bios. obviously not all motherboards are compatible this way. this depends on the chip itself.Comment
 When did you see FL1 files being used? Everyone is talking about chip reading and programmer! It doesn't work like that.Comment
 Hello everyone, I've gotten a hold of a Thinkpad W540, and unfortunately it is bios locked. really bummed out how the seller didn't tell me but here we are. I've made dumps of the 2 bios chips (25Q032, 25Q064. 4 mb and 8 mb respectively) and made sure to compare the files. I couldn't patch the 8mb dump as the auto patcher thought it was corrupted or not a correct dump. it did patch the 4 mb dump just fine. i've since then never touched the 8mb chip and just flashed the patched 4 mb dump to the 4mb chip with my CH341a. upon doing this, the laptop was essentially bricked and would not boot up. Powers on but the fans spin, no image and no beeping. I've tried to patch it and flash it a few times and removed the cmos, the external battery and the hard drive to no avail. The laptop works just fine with the stock bios, what am i doing wrong? Here are my dumps.Attached FilesComment
 Hi everyone! I'm having a problem trying to remove the password from my T480. I'm getting a weird tune on my thinkpad, and according to the Lenovo Diagnostics app, the error is 0285. Is there anything i can do? Already tried clearing TPM but nothing.
 Thanks in advance!
 Here is the original BIOS file and the patched one.Attached FilesComment
 Hello, could someone unlock this bios. This method doesn't work for me. Thanks in advance. Best regards.Comment-
 RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
 You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
 Your bios updated. Try to patch it againAttached FilesComment
 I uploaded the corrected BIOS but the password is still there and half of the functions cannot be changed in the BIOS.Comment
 Try first the "...new.bin" file and see if the laptop is booting ok and if it has password.
 If all ok you have the patched content also in the zip , write it and follow the procedure from the first post in this thread.
 In short:
 - Enter any character when asked for Supervisor Password
 - Press Enter when it shows Hardware ID
 - Press space bar 2x when asked
 - Turn off machine
 - Restore original BIOS
 Please provide feedback.
 S.S.Attached FilesComment
 Lenovo T580 when I go to write the patch file I get file size larger than ic size. I can read and write back the original file no problem but not the patch file. Do you know how to fix this?Attached FilesComment
 AsProgrammer v2.1.2
 Bios chips 25Q128JVSQ
 Post your programmer model, software version and bios chip part number[/QUOTE]
 Hello.
 Can someone please remove the Supervisor password from this rom?
 When I try to use autopatcher, it creates the PATCHED file and deletes it after a few seconds.
 Lenovo ThinkPad E14 Gen5
 Board: KE611/KE451 NM-F311 Rev 1.0
 Thank you in advance.Attached FilesComment
 [/QUOTE]
 Tried Neoprogrammer same thing see screen shot. I tried running the patch again but same thing. Only works when writing the original bin. Can you help.Comment
			by macabookHello everyone,
							Channel: BIOS Requests ONLY!
 07-24-2025, 02:17 PM
			by piratiHello everyone,
			by jbonavitaHi, my laptop wont boot at all
 Some issues
 Things I tried
 1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
