  • volinakis
    • Jan 2021
    • 2874
    • N/A
    #3621
    Originally posted by freesofia
    Hello, I did a dump on this exact chip, on a Lenovo X1 Carbon gen 5!
    The Verify also passed without any errors and I think the dump is correct!​
    that's not bios chipset, see pic
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1355
      • France
      #3622
      Originally posted by strasharo
      Did a few dumps, all of them are the same, but fail on autopatching with:
      Am I doing something wrong there?
      please remove thunderbolt password
      Click image for larger version  Name:	image.png Views:	0 Size:	368.9 KB ID:	3559482
      W25Q80
      Click image for larger version  Name:	406939719_907500864311308_3119104718927673419_n.jpg Views:	0 Size:	169.6 KB ID:	3559485
      • freesofia
        • Jan 2025
        • 7
        #3623
        Click image for larger version  Name:	x1_5.png Views:	0 Size:	1.15 MB ID:	3559465
        Wow, I dumped the wrong chip! Could you give me a joker, what is the model of the correct one, because it is erased and I can't see what it says! And EZP2019+ says this:
        Click image for larger version  Name:	image.png Views:	0 Size:	257.2 KB ID:	3559500
        Edit:
        Maybe this model!
        • strasharo
          • Jan 2025
          • 6
          #3624
          Yep, it worked with that one. Thanks a lot for the hint, really appreciated.
          Code:
          ./autopatch X1CG5_WB25Q128.bin
          Using UEFIReplace to inject 2 DXE drivers...
          [1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
          [2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd)
          Looking for volumes to patch...
          [1/1] NVRAM_EfiSystemNvDataFvGuid (checksum 2609h):
          Found volume at offset 800000h (checksum 2609h)
          Replacing volume.
          Done.
          PATCH FILE: X1CG5_WB25Q128_PATCHED.bin
          Good luck.
          Will now try to write it back.
          • freesofia
            • Jan 2025
            • 7
            #3625
            Thanks everyone for your help! We unlocked the machine! Stay safe and healthy!​
            • bardiasm
              • Jan 2025
              • 8
              I did the autopatch for my T470S and when I turn on the laptop it plays a melody once and screen is back. Please see my original and patched BIOS files attached.
              Thank you
              • volinakis
                • Jan 2021
                • 2874
                • N/A
                #3627
                Thank you
                post serial no and machine type - as in RULES of this forum
                • bardiasm
                  • Jan 2025
                  • 8
                  I apologize for not reading the rules first. Please see the details below:
                  Lenovo T470S 20JT-S0CJON
                  S/N PC0R5HFB
                  BIOS Winbond 25Q128JVSQ
                  • volinakis
                    • Jan 2021
                    • 2874
                    • N/A
                    #3629
                    S/N PC0R5HFB
                    try and follow steps from autopatcher
                    • volinakis
                      • Jan 2021
                      • 2874
                      • N/A
                      #3630
                      W25Q80
                      at least he's honest but I don't get it, there are 2 of them with the same laptop?
                      • bardiasm
                        • Jan 2025
                        • 8
                        I used the patched file you provided and updated the BIOS with AsProgrammer, but it still plays the melody and no screen after. Am I missing a step or doing something wrong?
                        • volinakis
                          • Jan 2021
                          • 2874
                          • N/A
                          #3632
                          If you put back your backup laptop works? Maybe you didn't backup your bios properly.
                          • bardiasm
                            • Jan 2025
                            • 8
                            I tried my backup after the second failed attempt and it works fine, laptop turns on and I was able to go to the BIOS settings without an issue, however the supervisor password is still there. Just to double check, do I need to do anything to the file you sent me or just program the BIOS with it?
                            • strasharo
                              • Jan 2025
                              • 6
                              #3634
                              It's the same laptop lol, I'm doing the firmware patching remotely, while freesofia is doing the hardware part. 😁 Thanks a lot for the help guys and sorry for the stupid question, it was our first time doing the procedure.
                              • volinakis
                                • Jan 2021
                                • 2874
                                • N/A
                                #3635
                                it means your bios has problem with ME_Region. Try patched clean_ME bios and follow steps from autopatcher.
                                • volinakis
                                  • Jan 2021
                                  • 2874
                                  • N/A
                                  #3636
                                  it's ok, I just was confused about who to reply. Enjoy, now you know what to do, usually bioses are containing 64, 128, 256 in the name, that one with 80 is for thunderbolt, don't touch it.
                                  • bardiasm
                                    • Jan 2025
                                    • 8
                                    First off I want to thank you for your help. Unfortunately this one didn't work either. I checked the error tone with the Lenovo diagnostic app and it's 0285 TPM initialization error.
                                    • bratapita
                                      • Sep 2023
                                      • 9
                                      • Poland
                                      #3638
                                      Have you removed the disk? Anti-theft switch pressed?​
                                      • myrose
                                        • Feb 2021
                                        • 9
                                        • türkiye
                                        #3639
                                        I don't know the bios password, can you help me?​
                                        • ingenieroedu
                                          • May 2023
                                          • 78
                                          • Colombia
                                          #3640
                                          Hello everyone, I have tried to patch the bin file as the post says, resulting in an error when I use the patched file it issues an error whose code according to the Lenovo application is the number 0285 This error code refers to "error related to functionality compatible with TCG (it may be a TPM initialization error)", any help is appreciated by the laptop, these are the data:
                                          lenovo e490
                                          motherboard model FE490-FE590-FE480 NM B911 REV 2.0 2019-01-17
                                          Type 20N9
                                          Number standard PF1405GJ
                                          Files attached both the original copy and the copy already patched with error 0285​
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
