    [QUOTE=Maxpower3;n3465661][QUOTE=Tokeri;n3465647]
    Originally posted by Maxpower3 View Post
    Click image for larger version  Name:	image.png Views:	0 Size:	625.9 KB ID:	3465663
    try
    Tried to change hash from offset 00170000h length 430000,
    Still getting the hash not matching error even after replacing hash according to guide
    Attached are the old and new hash, the binary file after replacing with new hash, and UEFITools screenshot
    My binary seems to be different to yours. Maybe upload your version and I'll try with that?
    EDIT: didn't see the uploaded bios, my bad
      [QUOTE=Tokeri;n3465813][QUOTE=Maxpower3;n3465661]
        [QUOTE=Maxpower3;n3465828][QUOTE=Tokeri;n3465813]
        I see. SOIC8 clip broke today, ordered one and it's coming in a few days. Will reply here if I'm not successful at unlocking the supervisor password with the bios
          Hi! I'm not very tech savvy but I have a few questions, so I apologize and would greatly appreciate it if anyone would help me/give me pointers.
          I recently obtained a 20Y0S26L00 (ThinkPad X1 Yoga Gen 6) and can no longer contact the original owner.
          It has an 11th Gen Intel so I am kind of worried this method will not work.
          When I boot, it complains about the date and time in the BIOS and I replaced the CMOS battery.
          However, it still complains and I tried to set the date and time in the BIOS and it seems there is some supervisor password. I can still access the BIOS without a password when prompted (enter with a blank password) but all of the options are greyed out.
          The machine can still boot to disk but is there any way for me to recover/reset/disable the supervisor password so I can set the date and time?
          Any and all help is appreciated!
            LENOVO X1 CARBON 7th generation
            serial number : pf1cew2x
            TYPE :20QE-S2W303
            1. TRIED AUTOPATCHER. CHECK OUTPUT SCREENSHOT.
            2. flashed with new file LenovoX1CarbonGen7_Patched.
            3. Keep beeping and repeating
            4. Replaced Original bin .
            How can be fixed? is it SHA mismatch? i don't know how to check. have a look at screenshots. Attached. both files.
            Thx for any help.
              Originally posted by alpitvraj View Post
              Cliquez sur l'image pour la voir en taille r?elleĀ   Nom : 		LenovoX1carbonGen7SVpassword.jpgĀ  Affichages :	0Ā  Taille :		527,5 KoĀ  ID : 			3467542
              TYPE :20QE-S2W303
              SHA mismatch?
              corrected but doesn't work on it 32Mo
              try maybe
                try maybe
                Thanks!, I will try
                  Thank you for your highly appreciated work.
                  I'm currently facing some issues with my T470S:
                  - I sat a Supervisor Password using special chars which was causing issues
                  - Access to BIOS was locked but I was still able to use my PC
                  2 weeks ago, I got an update of BIOS/TPM from Windows Update.
                  Computer restarted and after Lenovo logo a loading bar appeared and at the end something went wrong + an error popped.
                  Computer restarted one more time and I got the prompt for typing Bitlocker password.
                  I managed to boot into Windows and saw that TPM wasn't working anymore. PC in sleep mode would sometime beep with the code 0285.
                  Since I was locked from accessing the bios I used your patch to unlock supervisor password and successfully managed to go to BIOS but Security Chip option is missing.
                  I tried using the TPM Updater from Lenovo and reported version is 0.0.
                  Do you have any idea to fix that ? Thank you !
                    Hello, I am hoping you can help me. I have an E590 and I am trying to remove the bios password... I have read the bios and I used the autopatcher but the system does not boot, the caps lock and power LED illuminate, it plays a tune but nothing else. I restored the original file and it boots again. I've tried quite a few times with no success. Could somebody take a look for me? Thank you.
                    Lenovo Thinkpad E590
                    Motherboard:
                    Serial: PF-1G3YN9
                    Type: 20NB-001AUK
                      I have a Lenovo T540p supervisor password enabled bios.
                      I extracted and used the script but after re-flashing the laptop has no image displayed (I waited more than 5 minutes).
                      Output of the script seems fine:
                      Code:
                      Using UEFIReplace to inject 2 DXE drivers...
                      [1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
                      [2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd)
                      Looking for volumes to patch...
                      [1/1] NVRAM_EfiSystemNvDataFvGuid (checksum 2609h):
                            Not found... Skipping.
                      Done.
                      PATCH FILE: Bios-2024-09-23-bk1_PATCHED.bin
                      Here is the original bios, could someone give me pointers?
                        Thanks!, I will try
                        00005008 verification error
                          Hope someone can help - I followed your guide and created a patched Bios for my T480 20L5-CTO1WW S/N PF-1LT39A but when i tried to turn back on i got no LENOVO logo and only the beep code 01288 for a bad display so could not run the normal commands to complete the supervisor password deletion - checked the programming was done properly and verified also tried resoldering the chip but no change - i then returned progam on the bios to original .bin and it worked fine so i'm guessing the patch is not created correctly attached is my original and patched Bios .Bin file if someone can fix it please?
                            Hello, i have Lenovo L490 and Winbond 25Q80DVSI0 and i try to read flash to try to use this Auto-patcher but only flash i can read is 1MB size. I tried with CH341 programator. What can be a problem?
                              SMDFlea commented
                              Editing a comment
                              The 25Q80DVSI0 is not the bios chip.
                            Hi, guys:
                            I need HELP, Mine is Lenovo E450 , Please help me to remove Supervisor Password , PLEASE…
                            Greatly Appreciate.!!
                            attach original bios from lenovo
                              Originally posted by mva0001 View Post
                              Hi, guys:
                              The Autopatcher at post 1 should work on your model. The bios chip on your motherboard must be backed up using an SPI programmer, the bios from lenovo support is no good.
                                Hi guys i have an issue with autopatcher (trying to remove supervisor password on E560).I tried with python 3.8.5 but I don't get patched file.
                                ThinkPad E560
                                TYPE:20EV-S05200
                                SN:PF-OJYS8K
                                MOBO:BE560 NM-A561
                                CHIP:Winbond 25q64fv
                                Supervisor bios locked can someone help?
                                Thank you in advance.
                                I bought the laptop used for $20, I bought it as a home project (I'm a computer mechanic and maintainer, but we don't deal with bios problems = module installation, if the motherboard is faulty, then replacement).
                                Nobody in Hungary deals with lenovo KBC chip programming (chip replacement $70), Lenovo's opinion is to replace the motherboard
                                which is $150 from China. The SVOD programmer is $4,000, which is quite expensive for an 8-year-old machine.
                                That's why I'll either throw it all away, or buy a used donor laptop that doesn't have a password.
                                I thought that "LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal" was for this. It works for others on YouTube videos, so I don't really understand. The security chip was only used by Windows, it is not required on Linux, so if it is disabled, it should work. Maybe I'm thinking wrong?
                                  To try E560_PATCHED
                                    Thank you very much kordex 35, I managed to cancel the password.
                                      SVOD 4 is not $4000 .. more like $250 from the real sellers.
