 Try and reportAttached FilesComment
 Please Help ! ive got 3 T470s from my old company and every have supervisor lock, and a T450s with same problem.... but the 450s i dont save the original file ! thats a big problem i think.. for the first T470s ive got the Dump Bios Bin file here , i tried to make a patched file but its not working so please help... if i try to patch the original file the window open and close i tried with pyhton 3.8 and the latest with same Result
 Hello everyone. I will need your help please. I tried everything to unlock my L560 but the patched bios file will not work for me. The patching process was successfull but I only get a black screen and no fan noise after writing the patched file. After I write back the original bios file everything works fine - but with my bios password set.
 Can anyone try to patch my original bios file correctly that you can find attached?
 Thanks a lot for your help!Attached FilesComment
 serial number?Hello everyone. I will need your help please. I tried everything to unlock my L560 but the patched bios file will not work for me. The patching process was successfull but I only get a black screen and no fan noise after writing the patched file. After I write back the original bios file everything works fine - but with my bios password set.
 Thanks a lot for your help!----------------------------------------------------------------------------------------------------------------------------------------------------------------------
 ----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
 write this file and follow steps described in autopatcher:
 [ HOW TO USE THE PATCH ]
 STEP 1: Flash and replace current BIOS with the generated patch file
 STEP 2: Boot the machine
 STEP 3: Press ENTER/F1/etc. to enter BIOS settings
 STEP 4: Enter any character when asked for Supervisor Password
 STEP 5: Press enter when it shows Hardware ID
 STEP 6: Press space bar 2x when asked
 STEP 7: Turn off machine
 STEP 8: Restore original BIOS
 STEP 9: Reset BIOS settings to factory default
 [ NOTES ]
 When booting the patched BIOS you might have to:
 - Hold the anti-tamper switch down the whole time (use tape)
 - Remove the hard disk or replace it with a locked oneAttached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
 Thanks a lot - but what is the anti-tamper switch? Is it something I need to do if I am not want to put on the backcover?
 [ NOTES ]
 - Remove the hard disk or replace it with a locked oneComment
 Last edited by volinakis; 08-12-2024, 03:15 PM.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
 let it run for 2 mins, it will restart few times with no image, just wait----------------------------------------------------------------------------------------------------------------------------------------------------------------------
 Sorry for my late reply. I let it run for more than 10 minutes but the screen keeps black and no restart so far. I tried with power supply and also with battery.
 It is so strange. It is not the first time that I managed to unlock a L560. Maybe my bios dump is corrupt? Or can it be something else?
 you said that if you put back original backup it works. Only thing to do is to clean ME
 It is so strange. It is not the first time that I managed to unlock a L560. Maybe my bios dump is corrupt? Or can it be something else?----------------------------------------------------------------------------------------------------------------------------------------------------------------------
 Thats right. But after I write back the original dump, the bios password is still there.
 i dont know how to clean ME. Do you have a tutorial?
 i will give it another try tomorrow.
 Thank you, Everything worked perfectly as described. No issues. What a life saver!!
 Lenovo T480s Bios Ver. 1.57 02/27/2024 Model 20L8S5T700 CPU I5 8250UComment
 Hi guys i have an issue with autopatcher (trying to remove bios password on T450).tried with python 3.9, but i get no patched file eventhough it says it shoudl be done.
 I m joinig the orginal bios here, can someone help? thx a million
 https://www.badcaps.net/donateComment
			by macabookHello everyone,
							Channel: BIOS Requests ONLY!
 07-24-2025, 02:17 PM
			by piratiHello everyone,
			by jbonavitaHi, my laptop wont boot at all
 Some issues
 Things I tried
 1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
